Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Re-Routing Gas opening
Old 03-20-2006, 01:00 AM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Alright I have an idea about re-routing the gas door to behind the license plate like second gens. Now I'd like to hear what kind of work it would involve. I'm also wondering about the tube that leads to the tank, is it steel or rubber or what? Is there anything that I can use to re-route the opening to behind the plate? some sort of flex tubing but made out of what? The only way I'll do this is if I opt to make some fiberglass quarter panels but I'm still alittle uneasy about it. It would definately clean up the look more though. Anyways give me your thoughts and comments on the idea.
Old 03-20-2006, 03:48 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
In order to route the gas opening to behind the Lisence plate like a 2nd gen you would have to cut a hole through your "trunk" area. since the fuel tank sits right in front of that and pretty much flush with the floor. I can be done.. and it can be done to look nice.. you would just give up some of the space in that cubby hole. another problem you could run into.. is that the tank will never really be full.. since the tank sits about the same level as the rear plate. I believe anyhow..
Old 03-20-2006, 10:31 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I think this will end up being too big of a project.
The filler neck isn't flexible. You'll have to remove the tank, cut the the neck off, weld a new one on, cut a hole in the hump in the back of the car, weld the new filler neck on, run the neck (exposed to the interior of the vehicle) to the license plate area, create a safe mounting point for it, then fill the quarter panel.
Old 03-21-2006, 09:16 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
I am trying to work out putting the filler behind the drivers side tail light... It sounds interesting but until i finish it i don't know how well its going to work. I figured by putting it behind the tail light i can save the trunk space as well as make a trick gas filler that you would really have to look around the car to figure out.
Old 03-21-2006, 09:26 AM
putting the filler behind the light has been done and does work.. the one thing that you have to figure out though is how to swing the light out and swing it back in and lock it down do it does not move and does look like it should
Old 03-21-2006, 07:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think if you put a lid over your "trunk" area, so you have to lift up a plate to see the filler neck, it would be ok. you would lose that area, but I think filling that with N20 bottles or something would fill it nicely
I like the idea, if I really cared, i'd probably do it.
Old 03-21-2006, 11:17 PM
I have a drawing of how it would work with it behind the plate, and then one with it behind the tail light... i willl see if i can find them
Old 03-22-2006, 10:49 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
pics????, web links?
Old 03-24-2006, 12:38 AM
Engine: 305 V8
Transmission: auto
anyone???????
Old 03-24-2006, 10:06 AM
I remembe seeing a pick of one behind the tail light at one time.. still looking for the routing drawings and such.. migh be on my other computer...*sigh* been a long time since i fired that one up lol
Old 03-24-2006, 03:02 PM
Engine: 305 V8
Transmission: auto
ask an ye shall recieve
Old 03-24-2006, 11:01 PM
Engine: 305 V8
Transmission: auto
bump
Old 03-26-2006, 04:13 PM
Engine: 305 V8
Transmission: auto
herse something close
Old 03-26-2006, 06:40 PM
now extend that all the way back and you will have the filler neck for the "behind the tail light" setup.... that particular one is an ok deal. unless your hatch struts go out.. then filling up would be a major PITA
Old 03-26-2006, 07:39 PM
Engine: 305 V8
Transmission: auto
not my car
Old 03-27-2006, 05:26 AM
Xophertony's Avatar
Car: 1988 Trans-Am GTA
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
speaking of hatch struts WTF is the deal with the car in the picture?
Old 03-27-2006, 09:59 AM
thats easy.. the person took the hatch off when they were doing that. so the strut is basically just hanging by the mounting point at the top of the picture... it just happens to hang near that gas port... heh.. Personally.. I am going to put a fuel cell in mine.. which will still require me to open the hatch in order to fill the tank... unless i get mount it in such a way as to allow my to weld on a filler neck. at which point it would probably go out the erar somewhere... maybe not.. depends on what it looks like when i do it..
Old 03-27-2006, 09:30 PM
Xophertony's Avatar
Engine: 5.7L TPI
Transmission: WC-T5
Axle/Gears: BW 3.27
look at the length of the strut..... it's not a hatch strut.
Old 03-27-2006, 11:06 PM
Engine: 305 V8
Transmission: auto
I Think its one of those speedster camaros, you know the convertable with no back seat
Old 03-27-2006, 11:07 PM
looks like the hatch strut I have on my 83 and 84 z28... things are long... and that picture is of the back of the driver's side wheel well where most people have that little compartment.. not to mention look at the gas cap and then compare the size of a hatch strut that is fully extended to it..
Old 04-03-2006, 11:36 PM
Engine: 305 V8
Transmission: auto
cmon there has got to be more info out there about this
Old 08-16-2006, 08:57 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
so i cut my filler off the tank already to route it into the trunk area, but theres a vent tube inside, does the vent need to be connected?
anyone know what im talking about
Old 08-16-2006, 11:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's a convertible and that would be a trunklid strut, no hatch present.
To be more specific.. it's Graboid's convertible when he shaved the gas filler door...
https://www.thirdgen.org/forums/auto...?highlight=gas
Old 08-16-2006, 11:38 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Try this link:
1987 Pontiac Firebird - Redraif's Pontiac "RAIF Exterior"
Hope this helps.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
NastyEngines
Group Purchases
09-08-2015 10:14 AM
TBRays98
09-06-2015 05:05 PM
Quick Reply: Re-Routing Gas opening
