Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Tips for first time DIY crossmember
Old Jan 29, 2007 | 08:30 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I want to make a custom cross member to tuck my dual exhaust up a bit and I've seen it done many times on Horsepower TV so I think it's time to give it a shot. Any tips as far as what to avoid and what gauge steel I should be using? It's for about a 350 hp car with a 700R4.
Old Jan 29, 2007 | 09:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I made mine similar to a Spohn crossmember.
Support the tranny at the height you want it. Remove the old crossmember. Cut some angle iron and drill holes to mount it to the underside of the floor where the original crossmember was. There's extra holes for different crossmembers. Use whatever ones work best. Get some 1" steel tubing with a thick wall. Cut and trim 2 pieces so they fit between the angle iron and are on the front and rear of the tranny mount. Weld a plate between the 2 tubes for the tranny mount to attach to.
The underside of the floor isn't flat and the angle iron mounts are slightly staggered. It's not practical to make a real wide crossmember because there isn't any frame rails to attach it to. If you have SFC that run closer to the driveshaft tunnel, you could attach the crossmember to them. If they run along the rockers, that means an extremely wide crossmember.
I don't think you're going to gain very much for exhaust. You can't tuck the crossmember up any higher than what it already is without some custom bending of the tubes
Old Jan 29, 2007 | 09:54 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
When I make mine (information in a thread below) I used 1/8" wall 1" x 2" tubing. I used a peice of 7ga (3/16" steel) bent in a u for the trans mount. If you look in the thread below 1982 silver state project. I have extra of all of the parts that I made. I'll be happy to sell you some if you see something that you might find usefull.
Send me a PM if you need something.
Have fun. It is easy and great to say I built that.
Old Jan 31, 2007 | 05:33 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
With the 700R being wider than the t5 and t56 you may want to look into adding clearance in the other direction.....what I mean is to drop your cross member down in two spots so you can run the exhaust over it.......if you search you will find some have used the stock cross member and just added to it.....a couple of things to remember when welding under you car.......watch the fuel and brake lines on the driver side.....also take into account the speedo cable on the driver side of the tranny........good luck and make sure you post up some pics....as far as material it will depend on the design.
Mike
Old Jan 31, 2007 | 09:46 PM
Car: 86 T/A
Engine: HSR 355
Thanks for the tips, I'm going to look at it when I can get it in the garage and get a game plan.
Old Jan 31, 2007 | 11:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Originally Posted by Comp788
I used 1/8" wall 1" x 2" tubing. I used a piece of 7ga (3/16" steel) bent in a u for the trans mount.
Ya, that sounds about right but I think mine is just 1" x 1/8" round tubing. You could use a single tube if the tranny mount was gusseted or braced to the single tube. Sort of bend it in a U shape similar to an old G-body style tranny mount. It can hang off the front or back of the tube depending where you position the crossmember tube in relation to the mount on the tranny.
Old Feb 1, 2007 | 12:37 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I know others have posted a few pictures that might give you some ideas.
Some look like a 3" exhaust pipe that was sliced down the middle, using only half of it per side.
I think Evilcartman did one that looked really weird, like Spohns apparently. Used square tubing on that one.
Old Feb 1, 2007 | 04:07 PM
84ZMIKE's Avatar
Car: 84Z28
Axle/Gears: 3.73:1
Here is mine....
Mike
https://www.thirdgen.org/forums/fabr...ossmember.html
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
neekolzun
Aug 24, 2015 04:59 PM
Catcher55
Aug 15, 2015 07:08 PM
Elliswon
Aug 10, 2015 12:33 PM
