Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
sand bending pipes...
Old Jun 12, 2007 | 11:13 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
this looks like it would be awsome for a few different apps
http://www.theturboforums.com/smf/in...?topic=83119.0 can anyone say cheap custom headers
sorry forgot you wouldnt be able to see them if you dont have an account
Attached Thumbnails sand bending pipes...-index.jpg   sand bending pipes...-index2.jpg   sand bending pipes...-index1.jpg
Old Jun 13, 2007 | 04:33 PM
Car: 91 RS
Engine: 350 vortec
Re: sand bending pipes...
last one
Old Jun 13, 2007 | 05:04 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Good read, that is some cool stuff. I'm sure it will be massively time consuming to master that technique though.
Old Jun 13, 2007 | 06:13 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
I saw that on a movie once....I was wondering if it really worked.
Old Jun 13, 2007 | 07:05 PM
firstfirebird's Avatar
Brass trumpets are made by filling the pipe with water and freezing it. I've also heard of using compressed air. This is the first practical way of bending pipes without machinery I have seen.
Thanks SpototRs305 .
Old Jun 13, 2007 | 11:29 PM
Car: 91 RS
Engine: 350 vortec
i have used the compressed air to fix dentent tuned pipes before how are they using it to bend? is it really high psi or something?
Old Jun 14, 2007 | 02:47 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
i read that article a while back, its good stuff. though to make headers, you probably couldnt use this method and it be easy, because of the sharp angles and small lenghts of pipe,
Old Jun 14, 2007 | 07:08 AM
Yes.
Old Jun 14, 2007 | 03:33 PM
Car: 91 RS
Engine: 350 vortec
tried this today with some 1 1/2 BMI can do a circle with about a 3 1/4 ID dont see why 1 5/8 would be much harder... anyone know how much heat BMI can take
Old Jun 14, 2007 | 03:36 PM
How long did it take, and did you take pics? I'm very curious about doing this because of the cost of mendrels (not to metion all the welding involved).
Old Jun 14, 2007 | 05:32 PM
Car: 91 RS
Engine: 350 vortec
i only tried it out to play nothing constructive
well after spilling sand everywhere
then realizing it really needs to be DRY not sorta kinda dry
and you really do need a special tip for the torch
i used a small drill bit in a pin vise to open the center hole "a bit"
took about 10-12 minutes for a 360°
i will try and find a camera and see if wal-marts 1 hour photo actually takes 1 hour
Old Jun 14, 2007 | 05:44 PM
They usually will have "disposable" digital cameras, also. I am going to try it, but I need to go to my mother-in-laws to pick up the acetyline tanks and torch tips (inherited from my father-in-law ).
Old Jun 14, 2007 | 07:23 PM
Car: 91 RS
Engine: 350 vortec
one suggestion... dont seal the pipe air tight no pipe cap or anything like that... could get ugly
Old Jun 14, 2007 | 07:29 PM
Are you speaking from experience?!?
Old Jun 14, 2007 | 09:12 PM
Car: 91 RS
Engine: 350 vortec
you could say something like that the sorta wet sand i spoke about i guess built up some pressure before i decided the pipe cap is a bad idea unscrewed it shot out of my hand not what i was expecting
Old Jun 14, 2007 | 09:24 PM
You could have hurt yourself! I thought he packed the end with paper and left it open (I'll have to re-read it). He also said you should heat the sand in a barrel for quite a few hours to dry it.
Old Jun 18, 2007 | 10:28 PM
Car: 91 RS
Engine: 350 vortec
he did heat the sand to dry it and packed the end with newspaper but i didnt really have enough sand or the patience to dry it so i had packed newspaper into the pipe and cut a piece of broom handle to keep it packed not the best idea i have to admit but atleast i figured it out soon enough
Old Jun 24, 2007 | 05:55 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I tried this a couple of years ago after reading an article in car craft. At the time it didn't work to well. I tried 3" pipe and didn't have the correct tip for my torch. I have since gotten a rosebud tip and plan to try some 13/4" pipe. I think it will work.
Kory
Old Jul 6, 2007 | 07:15 PM
Dan W's Avatar
I saw something like this done while I was in Germany... very skilled tradesmen over there. The guy used a torch and two pair of pliers to bend some steam pipe (no sand or mandrel)... blew my mind with the quality of his work.
Couple of quick questions.
Can this be done with stainless steel?
Is there any reason you can't do roll cages using this technique? ie does it weaken the material?
Old Jul 6, 2007 | 09:12 PM
Stainless would be "stained" from the heat, I'm sure, much like it is from welding (or the blue/gold effect after exhaust has been through some heating cycles).
Unsure about the weakening of the metal.
Old Feb 25, 2008 | 12:51 AM
sheppyfire87's Avatar
do you think you can bend exhaust piping with this method?
Old Feb 27, 2008 | 11:41 PM
Aweasel's Avatar
Car: Red '89 IROC-Z
Engine: 350, Patriot 195s,
Transmission: T56, Hurst Shifter, Alum. DS, 3.73
in the article he claimed to have bent 12" diameter pipe with 1/4" thickness...with enough practice I'm sure roll cage pipe as well as exhaust pipe would be a breeze.
Old Feb 28, 2008 | 09:31 PM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
Here is some more details from a different source.
http://www.crystal-netbook.info/e158795/e171023/e171233
Old Feb 29, 2008 | 03:37 PM
thanks for that link it helped alot ill let you guys know how it turns out!
Old Feb 29, 2008 | 07:47 PM
I'm sure you can.
But why when exhaust pipe is so cheap?
Old Feb 29, 2008 | 09:49 PM
Aweasel's Avatar
Car: Red '89 IROC-Z
Originally Posted by firstfirebird
I'm sure you can.
mandrel pipe bender = $$$
sand and torch...ehh not so much, plus it's cool to tell your friends you bent your own exhaust lol
Old Feb 29, 2008 | 10:34 PM
I agree with you on the satisfaction of bending your own, but building them with a welder and header kits can be fun too .
You don't need a mendrel bender, I built several turbo kits and headers with a $129 welder.
Here's a good source for cheap pipes...
http://store.racing-solutions.org/bendkits.html
Old Feb 29, 2008 | 10:43 PM
that site is pretty helpful do you know of anymore stores/sites like that?
Old Mar 1, 2008 | 12:18 AM
91_Formula's Avatar
Car: 91 Formula
Engine: L98 350 TPI
firstfirebird - thank link is awesome!!! Thanks for sharing, those are great prices they have on those kits.
Old Mar 2, 2008 | 02:14 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
That is cool but over the years there has been better ways.
Hotrodboba400
Dec 10, 2019 07:07 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
gta892000
Sep 16, 2015 12:37 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
