Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Engine Paint???
Old Apr 15, 2008 | 09:45 AM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
Engine Paint???
Whats involved, can I just use high heat spray paint (cans) or should I look into a spray gun???
Old Apr 15, 2008 | 02:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Engine Paint???
I spray painted mine with Tremclad rust paint with rattle cans. 2-3 coats provides good coverage. I also had a new clean bare block to start with.
Of course there's very little you can see of my engine. The heads and intake are aluminum so they're not painted. The large tube headers prevent you from seeing the sides and the front motor plate only allows you to see the part of the block above the timing cover.
Old Apr 15, 2008 | 02:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Engine Paint???
yeah i used high temp engine paint on mine and it looks good. Havent got a chance to run it but you cant see much of it once its in the car like Stephen says alot of stuff blocks it
I have used that paint on my intke and valve covers and it worked well
Old Apr 20, 2008 | 03:41 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: Engine Paint???
Yeah the rattle can stuff from Dupli Color works awesome. I used it on my motor and haven't had any problems after about 8000kms so far. You have to make sure the block is completely clean from dirt and grease though, and they reccomend using their high heat primer as well (though I didn't lol).
Old Apr 21, 2008 | 03:25 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
Re: Engine Paint???
yeah the duplicolor engine enamel with ceramic works really well. thats what i painted my motor with. just make sure you dont paint over dirt and grease. paint tends not to stick very well.
Old Apr 21, 2008 | 05:27 PM
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
Transmission: 200-4r
Axle/Gears: 3.42 GN Posi
Re: Engine Paint???
+1 for Duplicolor
Old Apr 21, 2008 | 05:46 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: Engine Paint???
So what's an effective way to clean the grease and grime off, short of bringing it to a shop and paying someone?
Old Apr 21, 2008 | 09:37 PM
1BadElky's Avatar
Car: 86 El Camino
Engine: 355
Re: Engine Paint???
auto stores have degreasers, but they work best with a pressure washer. just avoid the alt, fuel system, distributor when spraying.
steam cleaning is another way.
gasoline is a good solvent.
after you use an oil-based degreaser listed above, use simple freen to remove that residue. then scuff the surface, and clean again with simple green and water. then you can paint.
this is the mothod I use to paint my frame anyway. my engine was already bare when I primed and painted it because I just had the block machined.
Old Apr 22, 2008 | 11:29 AM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Re: Engine Paint???
you can also use brake parts cleaner from any parts store. from my experiance it wont matter if you use genaric or the goog brakleen brand...they all do the same. just make sure you paint right after the brakleen evaporates.
Old May 6, 2008 | 07:32 PM
Mathius's Avatar
Re: Engine Paint???
A lot of people overlook the fact that a lot of those rattle can high heat paints need to be baked to achieve the total benefits.
Make sure you read the label.
Mathius
Old May 6, 2008 | 08:18 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Engine Paint???
I dont think to many people are gonna bake their engines though. lol
Old May 6, 2008 | 09:15 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Engine Paint???
Wouldn't they bake themselfs?
Old May 6, 2008 | 10:22 PM
Engine: L98 350 TPI
Re: Engine Paint???
That is what I was thinking too.
Kevin
Old May 8, 2008 | 10:38 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Re: Engine Paint???
you dont have to bake the 500 degree paint. only the 1500 degree stuff. it sprays on like a powder form. then it needs baked @ 600 for 60 mins. or let ur car idle for 60 mins. with gas prices the way they are and when you have to run 94 then thats when an oven comes in handy. IMO
Old Jun 11, 2008 | 01:19 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Engine Paint???
duplicolor high heat paint, always prime, eventually itll crack without it
prep work: spray with degreaser than wipe down with laquer thinner.
Old Jun 13, 2008 | 09:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Engine Paint???
My engine has been black, blue, and orange lol... all Duplicolor 500* paint, and all looked good!
Old Jun 13, 2008 | 09:50 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: Engine Paint???
You need to bake all of them to cure properly. If you bake it right after it dries, the paint will be in good shape, otherwise it could crack.
+1 for brake cleaner, and duplicolor
Old Jun 23, 2008 | 07:39 PM
Mathius's Avatar
Re: Engine Paint???
Ok, so if the manufacturers instructions say bake to 500 degrees for 20 minutes, can you guarantee you engine is going to get to exactly that temperature, not cooler or hotter, and hold that for 20 minutes?
Mathius
Old Jul 9, 2008 | 04:38 AM
83 Crossfire TA's Avatar
Re: Engine Paint???
Do you think that the paint really knows when it's been exactly that temp for exactly 20 min?
Old Jul 9, 2008 | 10:57 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Engine Paint???
I use brake paint then use metalic top coat and I get a wet look to the paint and it can handle about any heat I throw at it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
