Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
want to make cai but have questions
Old Apr 4, 2009 | 06:30 PM
Lestrey08's Avatar
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
what do you do with the pcv valve? this is on a multi port
Old Apr 4, 2009 | 07:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: want to make cai but have questions
..uhh, nothing? I don't get it, is this a trick question?
Old Apr 4, 2009 | 07:52 PM
Lestrey08's Avatar
Engine: 2.8 V6
no in the pics i see on here of ppls cai i never see a line or anything going back to the pcv valve do I just plug it off?
Old Apr 5, 2009 | 03:14 AM
83 Crossfire TA's Avatar
the pcv isn't connected to the cold air intake or the stock intake
Old Apr 5, 2009 | 07:48 AM
Mathius's Avatar
The PVC valve is in the top of your valve covers and usually has a hose going back to the manifold or somewhere else in the vacuum system.
I'll bet he's talking about the IAT or IAC sensor whatever the hell it's called that reads the incoming air on a MAP or MPFI v6 design on the 90 and up F-Bodies.
You should make provisions for this in your CAI design. It needs to be plugged into the airflow somewhere.
Mathius
Old Apr 5, 2009 | 03:11 PM
Lestrey08's Avatar
Engine: 2.8 V6
oooooh ok thanks
Old Apr 5, 2009 | 08:49 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
no he's not..the little tube on the left side of the throttle body..multi port 2.8 v6 .connect to the air and to the pass side valve cover black metal tube..if you are keeping all that on there just cut a hole in the pipe and connect with a rubber fitting..i pulled all my a.i.r. stuff off and reran my vac lines.... wouldn't do it if you don't know how...
Old Apr 6, 2009 | 05:24 PM
Mathius's Avatar
How does the throttle body become in the way of a CAI? All MPFI's had that tube. It's nowhere near in the way of a cold air intake. Hell, the later 3.1L's had an induction setup from the factory that was VERY similar to a cold air intake. All you'd have to do is make a new filter housing and go to a different filter.
Here is the stock pcv. Nowhere near the intake.
Here is the tube you're worried about.
Note the stock intake tube already flows towards the passenger side fenderwell where a CAI would be applied.
Mathius
Attached Thumbnails want to make cai but have questions-365689_10_full.jpg   want to make cai but have questions-365689_6_full.jpg   want to make cai but have questions-enginesidesmll2.jpg
Old Apr 6, 2009 | 05:28 PM
Mathius's Avatar
Here's another CAI on a v6:
Mathius
Old Apr 6, 2009 | 11:51 PM
snowman383's Avatar
Engine: 350 crate
Mathius
that is not stock setup this pic is see the diff
you don't have the a.i.r on yours ether..its the tube that runs from pass side valve cover to the a.i.r.. then to the flex tube on the throttle body..it would fit between you alt and intake ..right above the idler pulley ..my 2.8 had it till i took it off
Old Apr 7, 2009 | 08:11 PM
Mathius's Avatar
No, that IS the stock setup, it's just different from yours. I've never seen one like yours. Older car?
Mathius
Old Apr 7, 2009 | 08:31 PM
denice25's Avatar
NOTHING!!!!
Old Apr 7, 2009 | 08:40 PM
snowman383's Avatar
Engine: 350 crate
mine is an 88 bird
Old Apr 7, 2009 | 11:22 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
when i did my cai there was a hose on the passenger side. but the pcv valve is on the drivers side. the hose on the pass. side you just connect to the cai. (the kit i used had a adapter to stick it on) also you have to relocate the air temp charge sensor. thats pretty easy tho. i just drilled into the tubing and bam, done. so no, you dont have to touch the pcv at all
Frozer!!!
Jan 19, 2024 04:55 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
Fronzizzle
Aug 9, 2015 01:15 PM
