Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
RPM activated switch for custom shift light
Old Oct 28, 2009 | 07:46 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
anyone know where i can find a RPM activated switch, im wanting to take that upshift light thats in the cluster and turn it into a shift light..... or i may use a small bright LED else where, either way i want a "hidden" shift light
Old Oct 28, 2009 | 08:57 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: RPM activated switch for custom shift light
Autometer makes them, just pick the chip range you want and plug it all in!
Old Nov 3, 2009 | 09:05 PM
89RS_82Z's Avatar
i havent seen ones that dont allready have a blub and lense on them, im really looking for a module that has output 12V+ to activate a custom or hidden light
Old Nov 3, 2009 | 09:11 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Well, if you don't want to use their light behind your lens, then use the MSD rpm activated switch and hook it up to whatever you want.... A bit easier and cheaper to use a ready made light behind a lens, but I guess you can do it anyway you want.....\
http://www.summitracing.com/parts/MSD-8950/
Old Nov 3, 2009 | 09:17 PM
89RS_82Z's Avatar
hmmm, kinda pricy, but i got an idea, i may take an autometer shift lite apart, and get the wires going to its shift light and cut them run them to my light, and just throw the autometer one under the dash
Old Nov 3, 2009 | 09:20 PM
89RS_82Z's Avatar
hmmm found this
http://cgi.ebay.com/ebaymotors/Summi...item5636857f45
Old Nov 3, 2009 | 09:50 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
I have used Summit's older version of that switch for a while now and it works great for for the application that you want it for.
Old Nov 4, 2009 | 05:44 PM
89RS_82Z's Avatar
what you want shipped to 36532
Old Nov 6, 2009 | 08:36 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
sorry, misunderstanding, don't have one to give just saying that it works well
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
tnrednneck
Aug 13, 2015 08:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
