Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
84 power bulge FLapper unit..
Old Mar 26, 2010 | 06:53 AM
jbucago's Avatar
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
any one have any ideas about this... i wanna install the one i found today... the solenoid works but im not really satisfied with just hearing that flap open and shut.... i have a micro switch on the throttle body lever of my TBI....
any ideas.. what have you done with this..
Old Mar 26, 2010 | 08:22 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 84 power bulge FLapper unit..
What is this?
Old Mar 27, 2010 | 05:06 AM
jbucago's Avatar
it was the unit that was under the power bulge hood that opened a flap to let cold air in...
i think it was only 83-84 im not sure.
Old Mar 27, 2010 | 07:32 AM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Flapper unit
Old Mar 27, 2010 | 12:00 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Wasn't that vacuum operated?
Old Mar 28, 2010 | 06:18 AM
jbucago's Avatar
well this just has a solenoid and looks like it runs off of a switch i guess..
Old Mar 28, 2010 | 06:47 AM
Car: 1987 IROC-Z
Transmission: TH350
Can you post a picture?
jbucago's Avatar
SO i installed one.. and there is only 2 wires comming out of the solenoid.. and i have an 89 formula 5.0 tbi i wonder what i can wire them up to... maby like a micro switch where the throttle body linkage is.... any thoughts?
Old Mar 28, 2010 | 06:49 AM
Car: 1987 IROC-Z
Transmission: TH350
How big are these micro switches? Depending on size and how exactly they work, I may have a use for one.
Old Mar 28, 2010 | 02:49 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have the hood on my car and the flapper unit sitting in my parts storage. I too want this thing on my car because of the water that comes in. The best bet it to mount a power lock motor in place of that vac one and wire it up to a switch in the car.
Old Mar 28, 2010 | 04:42 PM
jbucago's Avatar
yeah same here i made a big mistake taking out the plate on my 89 on the power bulge and then water got in and messed up a few coils and distributors... but now that i have this unit in... i dont even have a problem washing my car... i wonder what the factory hooked up them wires too... comming from the solenoid
Old Mar 28, 2010 | 11:37 PM
my89's Avatar
Car: '89 Formula
Engine: 305 TBI
what is a power lock motor?
Old Mar 29, 2010 | 04:03 AM
jbucago's Avatar
door lock actuator.
Old Mar 29, 2010 | 05:22 AM
screeminchicken's Avatar
There is a drip tray that comes with to avoid the water problem. I have nos complete setup out of a 83. dont have the correct hood yet.
If ur engine is carb you can get a vaccum switch and then wire the solinoid to the vaccum switch.
i guess with efi engine, you could possibly get a voltmeter switch from radioshack or something to wire it to the maf. just an idea
good luck .....post up some photos on what you end up doing
Old Mar 29, 2010 | 05:43 AM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
depending on the voltage requirement, could you use the TPS reference wire?
Old Mar 29, 2010 | 06:55 AM
jbucago's Avatar
well it seems i did somthing wrong... i blew the solenoid or somthing.... it doesnt work anymore... it was working, but now its not.. i guess im just gonna leave it open for now until i find like a door lock actuator or somthing to the same effect, to use the same motion... i cant find these solenoids anywhere... i really wanted it to work. anyways i will get pics up asap... BTW im using a duel snorkel air cleaner with the 84 power bulge unit LID... so cold air from both snorkles and then the cold air from the power bulge unit.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
