Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
headlight (high beam) ram air
Old Aug 25, 2010 | 06:26 PM
  #101
wrenchbender's Avatar
Re: headlight (high beam) ram air
Originally Posted by TheMonster
Yeah I know I was just wondering, I already fabbed a dual snorkel as you can see earlier in the thread. I was just wondering if it was a full kit, or the "kit" for the hoses, because I used the same tubing for it.
Yep, you're right! Goes to show how good my memory is! Yours looks great as well!
Old Aug 25, 2010 | 08:49 PM
  #102
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Thanks, both get the job done. Either one cost money/time, and a great improvement on the car. I get a ton of questions and compliments, or one of those "What are those black things next to the headlights?" Until I lift up the hood.
Old Sep 30, 2010 | 02:55 PM
  #103
rdsxfn524's Avatar
or like this o wait, that's not a ram air port haha
Old Aug 10, 2012 | 12:56 PM
  #104
pauly T's Avatar
Where did you find the hood on your Camaro?
Old Aug 10, 2012 | 12:58 PM
  #105
pauly T's Avatar
Where did you find that hood
Originally Posted by billybob6110
thats what i wanted it to look like. btw my car is NO where near a ***** car. anyways i think itd look sweer smoothed out and have some sort of mesh painted black in front of the tubes inlet
Old Aug 20, 2012 | 03:53 PM
  #106
nheller76's Avatar
Car: 89 RS Camaro
Engine: Original 2.8 v6 convert to 5.7
Transmission: Th400
Axle/Gears: I think its the 3.42
Has anyone tried using the stock TPI intake that fits into the bumper. Their is a teck article on how to make that a ram air set up?
Old Aug 20, 2012 | 04:28 PM
  #107
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Originally Posted by nheller76
Has anyone tried using the stock TPI intake that fits into the bumper. Their us a teck article on how to make that a ram air set up?
https://www.thirdgen.org/ramair
Old Aug 20, 2012 | 08:41 PM
  #108
nheller76's Avatar
Car: 89 RS Camaro
Transmission: Th400
Exactly, I've been playing with a way to use that ram air set up with a carb. That might work better and you would still be able to keep the hi beams and maybe one day convert to cooler looking head lights?
Old Aug 21, 2012 | 06:21 AM
  #109
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
here's what i did when i replaced the 2.8 V6 with a vortec headed 305 in my 86 Camaro:
i don't know what the stock baffle setup for the V6 looks like since everything below the stock filters was cut off when i got the car, but i opened up the grille and built a NASCAR style airbox that gets all the air that cools the radiator and feeds the carb out of coroplast. NO air from under the bumper is directed up thru the radiator or into the carb any more. this is a VERY effective ram air setup- the carb stays so cold even on hot days that water drips off the sides of the carb like a glass of ice water on a humid summer say and the fast idle cam on the choke actually engages when i go more than a few miles down the road. in fact, i taped off most of the grille and the car is cooled and the engine fed air from a small section at the bottom of the grille in an effort to get the engine to run in the area of 210 degrees for a little more efficiency and to make the car a little more aerodynamic. actually, i put another strip of tape below the last strip, so the openings are only half as big in this pic and it stays cool and feeds the carb plenty of cool air:
i know it looks kinda hokey, but the whole car looks kinda hokey.. i am, after all, using lawn edging, coroplast, furnace air return vents (on the hood- spiffy, eh?) and duct tape as aerodynamic devices.
regarding the original subject of this thread: the 5.0 Mustang guys made removing a headlight and putting a ram air tube there "cool" in the late 80's, then the ricers copied it about 10 years ago.. do we really want to copy something that Mustang and Honda guys did first, when we've got a more aerodynamic and cleaner looking factory engineered option available to us?
Old Aug 21, 2012 | 09:06 AM
  #110
Car: GTA
The "headlight removal for ram air" mod goes all the way back to the 80s (at least....it would not surprise me if it was even older than that) so don't try to suggest that the Mustang guys started it in the 80s.
Old Aug 22, 2012 | 02:01 PM
  #111
novaderrik's Avatar
Car: 86 Camaro
they didn't start it, but they made it "cool".
Old Jul 8, 2013 | 07:41 AM
  #112
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
sorry pauly t i got it from glasstek 4 inch bolt on. cost me 378 shipped way back when
Old Jul 9, 2013 | 10:12 PM
  #113
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
^^ Lol he said NASCAR style ram air
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
bryan623
Aug 10, 2015 11:33 AM
