Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
double hump xmember for the T5?
Old Jul 13, 2010 | 02:51 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Has anyone made one or make one? pictures?
Old Jul 14, 2010 | 04:49 AM
83 Crossfire TA's Avatar
Re: double hump xmember for the T5?
Have you looked under your car? That's sort of a mustang thing, it's not the lowest point on a 3rd gen or wide enough with enough clearance going up to run anything substantial through there if you did make one.
Old Jul 14, 2010 | 04:30 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
To do this
Old Jul 14, 2010 | 04:31 PM
You need to do this
Old Jul 14, 2010 | 04:32 PM
Unless you want to do that much work to your car go a different route.
Old Jul 14, 2010 | 04:37 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I made one for my T56. Not sure if the length difference would make it harder or not for the T5.
Old Jul 18, 2010 | 10:36 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
it is the lowest point under my car when your running longtubes on a lowered car.I guess the only route would be to go with making my own,i know they make one for the T56 but i dont know of the differences between the 2 braces..
Old Jul 19, 2010 | 01:18 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Heres mine for my T56 and I know I made one for my old T5 that is somewhere around here that im not using anymore
Old Jul 19, 2010 | 06:19 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
That would be great if you could fine it pm me please
Old Jul 19, 2010 | 08:15 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If you use good SFC like Alstons that don't use the outter edges of the car, there is plenty of room down the two sides to run pipes in that valley where the floor pan n sides meet.
Where I run mine.
Old Jul 20, 2010 | 12:44 PM
6SIX6's Avatar
Car: 89 IROC
Workin on getting pics but it might not be for a few days as I think the X-Member is at my shop and i wont be going there till sunday night
Old Jul 26, 2010 | 02:27 AM
6SIX6's Avatar
Car: 89 IROC
I havnt forgotten about the pics but i havnt gone to my shop yet as its an hour from my place to get the x-member. This week for sure
Old Jul 26, 2010 | 07:55 AM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Ok that's fine I'm in no hurry at the moment as I gotta tear my motor apart to find a knock
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
skinny z
Oct 5, 2015 06:23 PM
thekurlyone
Sep 30, 2015 12:54 PM
IROCNParts
Sep 24, 2015 10:50 AM
