Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Motor mount inserts
Old Sep 2, 2010 | 10:18 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Motor mount inserts
does any one know how to install this?...
http://www.summitracing.com/parts/ENS-3-1130G/
Old Sep 2, 2010 | 10:27 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Motor mount inserts
You have to drill the clamshell mount open, I believe it's riveted together.
Old Sep 2, 2010 | 10:38 PM
Car: 1983 Z-28
Engine: 5.7 L
ok...yea it is...but after that do i just us the ties to put it back 2gether?...
Old Sep 2, 2010 | 10:46 PM
Mhmm. Or you could rivet them together again, your call
Old Sep 2, 2010 | 10:56 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...is that hard 2 do?...
Old Sep 2, 2010 | 11:01 PM
I wouldn't say it's difficult, but I never actually did this (on the motor mounts) so you may want to have someone else chime in. I just ran solid mounts, lol
Old Sep 2, 2010 | 11:05 PM
Car: 1983 Z-28
Engine: 5.7 L
o ok...thanks ill just go ahead and try it with the ties...how does the car run with the solid mounts?...does the car rumble?...
Old Sep 2, 2010 | 11:10 PM
Put it this way...
With the car idling, I can clearly watch the antenna on the fender swaying from the idle. I can't say how it compares to poly or even rubber bushings though, because I put the new mounts in at the same time I swapped from a V6 to the 355. But there is certainly a "shake" to it, you can feel the idle through the car, not just hear it
Old Sep 2, 2010 | 11:20 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks....thats all i need to kno...
Old Sep 3, 2010 | 12:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The ties are to hold it together until you get the bolts in. Once it's bolted down, it doesn't need anything else to hold it together.
Old Sep 6, 2010 | 09:58 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
I didn't even need the ties to get my bolts back in.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
