Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Buddys 4th gen cold air kit
Old Dec 5, 2010 | 01:40 PM
iroc-z_23's Avatar
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
He had all the piping and PVC already made and has a plate where these pipes fasten onto. Supposed to gain a couple mph in the 1/4
(had to cut the radiator support to fit the piping)
Old Dec 5, 2010 | 02:06 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
Re: Buddys 4th gen cold air kit
cool i like
Old Dec 5, 2010 | 09:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
And how are you going to do that to your third gen? This isn't a fourth gen forum.
Old Dec 5, 2010 | 09:44 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I think he's just showing everyone that you yourself can fabricate something cool vs purchasing it.
I like it.
Old Dec 5, 2010 | 09:47 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
I like it too, but he is taking a lot of airflow away from the radiator ..mmmhhhhh
Old Dec 5, 2010 | 10:25 PM
iroc-z_23's Avatar
Engine: 355 SBC
third and fourth gen both have the same principal of air box and has the 2 inserts from the grill. This can EASILY be done on a third gen and it gets the idea out there for maybe some improvements. Almost everything can be swapped from fourth to third gen so that's probably the coolest post from a moderator I've seen. Congrats
Old Dec 5, 2010 | 10:32 PM
iroc-z_23's Avatar
Engine: 355 SBC
I Realized that too but i mean if a car has fog lights it's not getting too much better airflow I guess.. A bunch of people have done this but not with piping, they used dryer hose. Just going to take some driving to see how it works
Old Dec 5, 2010 | 11:36 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
lets hope he dosent have to drive it in the rain.. i would recomend drilling some holes int he very bottom of the pipes that are in by the grill.. just to let any water that gets in there out..
Old Dec 6, 2010 | 12:05 AM
iroc-z_23's Avatar
Engine: 355 SBC
This is mainly a drag car. Has big Hoosier dot slicks and skinned in front.. Won't see much rain at all but I do think thats a good idea if there would happen to be water sitting there
Old Dec 6, 2010 | 12:39 AM
I am not talking about the inlet..more so about the pipes infront of the radiator !!!!
Old Dec 6, 2010 | 06:56 AM
iroc-z_23's Avatar
Engine: 355 SBC
There's no a/c condenser so that helps, and there's still a lot of room where air can flow through radiator
Old Dec 6, 2010 | 07:00 AM
iroc-z_23's Avatar
Engine: 355 SBC
If it maintains the same water temp as before with this cold air kit in it I don't think the pipes are effecting air flow to the radiator too much
Old Dec 6, 2010 | 09:02 AM
correct, but does it ???
Old Dec 6, 2010 | 10:57 AM
iroc-z_23's Avatar
Engine: 355 SBC
Yeah it does, he drove around town and it was fine
Terrell351
Jun 13, 2021 01:13 PM
kyle5647
Aug 15, 2015 11:56 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
