Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Subframe connector question
Old Jan 16, 2011 | 09:20 PM
rowdy_51's Avatar
Is it difficult to fab subframe connectors for an 84 Z28. If anyone has done this what are the measurements?
Old Jan 27, 2011 | 09:50 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Subframe connector question
Easy.
Old Jan 28, 2011 | 06:13 PM
dead sailor's Avatar
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
If you're not sure what to do you're better off buying a set of sfc's and putting them in.
Old Jan 29, 2011 | 02:10 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Pretty simple really, to save me some headache na a few $ I mocked mine up first. I started by using 2x4's that i ran through the table saw to get to the correct size square tubing I was using 1.5 x 2 in my case. Mine do not follow the floor, but actually intersect it, so no real bends. I them made my end peices to wrap around the front LCA mounting point. Took a few measurements and made my pieces to tie into the front frame rails.
Old Feb 9, 2011 | 02:45 PM
boby47's Avatar
Car: 84 Z-28, original owner
Engine: 305HO,+.030, mild cam
Transmission: TH700R4
Axle/Gears: 3.08, highway gearing, posi
a whole lot quicker and easier to pop for $200 or so and get a set of the Alston sfc's from Lon at Top Down Solutions - they fit, they go on easily, and require only a very minor fuel/brake line bracket bend to clear everything. powdercoated.
Old Feb 9, 2011 | 03:10 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
alstons are only good for drag racing...get the outer BMR sfc's if the car is gonna be used for autox or road racing..
Old Feb 10, 2011 | 12:32 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I have a set that I believe someone fabbed, I'll look for them tomorrow and get pictures and measurements (unless they are buried under 2 feet of snow). I think a local guy made them but I could be wrong.
Old Feb 15, 2011 | 08:01 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Did you ever find them ? To post some measurements?
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
