Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
For those who have the 3rd brake light on the glass.....
Old Aug 20, 2012 | 08:53 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Here is what I did to mine: The lens I sanded it completely smooth, then smoked it, almost looks black in the picture. The housing I sanded down, primed with gray acrylic primer, then painted gloss black and then cleared
Attached Thumbnails For those who have the 3rd brake light on the glass.....-0820121908a.jpg   For those who have the 3rd brake light on the glass.....-0820121902a.jpg   For those who have the 3rd brake light on the glass.....-0814121700a.jpg
Old Aug 20, 2012 | 11:00 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: For those who have the 3rd brake light on the glass.....
looks good. do u have a few more pics from behind a little further back?
Old Aug 21, 2012 | 07:53 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
not yet, it was gettin to dark. i'll get some this afternoon. thanks!
Old Aug 21, 2012 | 11:33 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Here are some more pics
Attached Thumbnails For those who have the 3rd brake light on the glass.....-0821120946a.jpg   For those who have the 3rd brake light on the glass.....-0821120945a.jpg   For those who have the 3rd brake light on the glass.....-0821120946b.jpg
Old Aug 21, 2012 | 11:36 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
and a couple more
Attached Thumbnails For those who have the 3rd brake light on the glass.....-0821120946d.jpg   For those who have the 3rd brake light on the glass.....-0821120946c.jpg
Old Aug 21, 2012 | 11:37 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I'll post some more of it lit up when I get it hooked up
Old Sep 5, 2012 | 11:40 PM
DancesWithDeath's Avatar
Car: 1991 rs camaro
97 Cadillac deville. Damn I'm good
Old Sep 6, 2012 | 12:14 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
nice, i love the small details
Old Sep 6, 2012 | 08:47 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Thanks!, I got it workin but I have to plastic weld it back together and a few other things
Old Sep 17, 2012 | 08:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
is that a replacement hatch or what? that brake light is pretty much and 86 only bit. Unless the car has some very unique options and deletes.
Looks good regardless, i may do this to the light om my 86, clean the lens up a little.
Old Sep 17, 2012 | 08:49 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
the old hatch busted when I shut it and the only one I could get was off an 86, the original hatch had the 3rd brake light under the spoiler. Thanks tho! The best way to do it is take a da sander with some 80 grit, sand it almost smooth, then take 180/220 and smooth it completely, then wetsand with 600
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
