Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
wiper motor delete idea
Old Feb 24, 2014 | 11:13 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I have always wanted to get rid of my wiper motor. It is just big and ugly in my eyes. This sparked me to look at other cars in shows to see what they do. I have seen many times, 69 camaros have smooth firewalls yet still retain wipers. After some searching, I found at least one guy using a VW Passat (I think) wiper motor that was mounted IN the cowl area. This seems like a viable option for me, but wanted to see if anyone here has done something similar.
If I had it my way, I would just delete the wipers alltogeather. I don't plan on ever driving this car when it is not perfect out. But the state of MA says you need to have wipers, so it looks like they are staying, but I refuse to use that huge motor under the hood.
Ideas?
Old Feb 24, 2014 | 11:33 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: wiper motor delete idea
If it just has to pass a visual inspection you could remove the motor and all related gear and just thread a nut on the backside of the wiper arms to keep them in place.
Old Feb 24, 2014 | 12:02 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Yep I hear ya. Each year I get my car inspected, then I go home and remove the motor and tuck the custom harness I made under my dash.
I have a red cap that I made, and just place it over the hole. It looks so much better!
You can also replace our motor with a smaller motor from an 89-94 Nissan Maxima.
Old Feb 24, 2014 | 06:28 PM
Engine: LS3
How does it wire up? I don't have any wiring that is stock. Car is wired with painless harness.
Old Feb 24, 2014 | 06:40 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't know how they do visual inspections where you come from, but around here the tech must visually observe the windshield wipers wiping the windshield.
-- Joe
Old Feb 24, 2014 | 11:28 PM
Car: 89 Formula
Engine: 383 SBC/HSR
I don't know I've never tried it, but it can't be that difficult. I read on another thread where it was done. I think you only get one speed from the motor. But, if you don't drive your car in the rain, then that's all you'll need for your inspection.
Anesthes, I think you're right...they do have to be working at the time of inspection.
Old Feb 25, 2014 | 06:55 AM
Engine: LS3
OK, I will do some searching. Thanks for the lead. I only need one speed. Just don't want to bother with that huge stock motor/wiring.
Old Feb 26, 2014 | 06:32 AM
Engine: LS3
Anyone who has wired the Nissan motor know what wires get voltage to get the one speed going? I am sure it is not hard to figure out, but just want to see if anyone knows already. I will just pick up a used motor on ebay. There are tons for around $20.
Old Feb 26, 2014 | 06:52 AM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
i have a couple of nissan manuals about, mostly r32/r33/r34,s13/s14/s15
so if any of those help i can get wiring pin outs for you.
Old Oct 31, 2018 | 10:55 AM
rgauder's Avatar
Car: 1987 Trans Am
Looking for the info of how to wire the Nissan motor to the thirdgen harness.
Old Oct 31, 2018 | 04:53 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
same here
post info/pics if possible
Old Nov 15, 2018 | 04:38 AM
VAN454's Avatar
Car: 88 GTA
Engine: Ls1
Axle/Gears: 9 bolt 3.27
Does anyone know which thread the nissan wiper motor swap is in? I can't find it
Old Nov 15, 2018 | 09:20 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would go for a 4th gen wiper motor. It should be easy to retrofit into the 3rd gen, and if you get a 4th gen wiper switch, you can make it all function like stock. The 4th gen wiper motor is much smaller than what we have, plus they all do the park position like we need
Old Nov 15, 2018 | 09:28 AM
rgauder's Avatar
Car: 1987 Trans Am
I know that there is someone who has used the Nissan motor. Just looking for some more info on it please.
Old Nov 15, 2018 | 10:09 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I thought you were already trying this? In the other thread you even posted a wiring diagram for the Nissan.
Old Nov 15, 2018 | 12:29 PM
rgauder's Avatar
Car: 1987 Trans Am
​​​​​​Yes, I have found a motor and the diagram but am not skilled enough to figure it out.
Old Nov 22, 2018 | 04:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Ive read (here) the later s10 motor also works.The 98-up passat looks alot like the current 5th gen camaro set-up.I would guess you need a wiper motor w/ at least as many wires to connnect to, since the 3rd gen w/delay has six (cover), plus the 3 on the motor end.Some of those are duplicate as they go to the cover, but other brands only have 2-3 wires.The s10 uses five.At least one on the 3rd gen is a ground.
passat
camaro
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
nuggie
Aug 25, 2015 01:27 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
slade5612
Aug 11, 2015 07:19 PM
