Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lowering engine
Old Apr 9, 2014 | 12:52 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Lowering engine
I may need to lower my engine a 1/2 inch for hood clearance issue with air cleaner. I will be running a small block with perf RPM intake Holley 4150 carb and flat 84 Z28 style hood. Thanks for any help.
Old Apr 10, 2014 | 08:05 PM
19CAMARO85's Avatar
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: Lowering engine
Thinner air filter or another intake honestly. You dont want to mess with the motor trans alignment.
Old Apr 11, 2014 | 02:17 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: Lowering engine
Just look at the distance between the oil pan and the k-member. I doubt you will be able to go down an inch unless you hack up your k-member and like mentioned above you will then change the angle of your drive line.
Old Apr 11, 2014 | 07:20 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Lowering engine
I am only looking to lower 1/4 to a 1/2 inch and was wondering if anyone has done this...thanks for any help
Old Apr 13, 2014 | 08:53 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: Lowering engine
I lowered my motor in my car but I have a motor plate not factory mounts. I recommend a modified air cleaner.
Old Apr 14, 2014 | 05:45 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Lowering engine
You would need to use a custom made solid motor mount since I do t believe there is enough room to use a two piece mount like factory.
Get a different air cleaner or a raises/cowl hood. Lowering the engine will create clearance issues with the oil pan and exhaust, also the oil pan may sit lower then the subframe and thats not a good idea.
Old Apr 14, 2014 | 07:52 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Lowering engine
get a drop base air cleaner. you can easily lower the filter an inch or more.
http://www.summitracing.com/search?k...20air%20filter
Old Apr 14, 2014 | 08:41 AM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: Lowering engine
I'm using a performer rpm intake with a 3/4" adapter to my qjet and a drop base air cleaner with a 2" filter in my 84 and it fits
Old Apr 14, 2014 | 10:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Lowering engine
Same here. Front and rear motor plates with no side mounts. Mine is lowered and pushed back as far as it would go between the frame rails but you'll be much better of getting a drop base air cleaner or investing in a low cowl hood.
Old Apr 15, 2014 | 07:57 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Lowering engine
What style hood are you using?
Old Apr 15, 2014 | 09:51 AM
Gsoleski's Avatar
Car: 1984 Z28
Re: Lowering engine
The stock hood without insulation
Old Apr 15, 2014 | 01:15 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Lowering engine
Thank you for info
Old Apr 18, 2014 | 06:43 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: Lowering engine
Ed quay makes a lower side mounts, there is also a guy on racing junk that sells up to 3 inch drop air cleaner. I bought one and it is a great piece
Old Apr 18, 2014 | 09:46 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Re: Lowering engine
Thank you for information.... I will look into it
89GTAOz
May 16, 2020 09:31 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
