Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Lakewood Drive Shaft Loop
Old Sep 25, 2014 | 09:03 PM
skinny z's Avatar
Has anyone installed one of these? Any problems or interference?
I've got an UMI adjustable torque arm with the trans mounted bushing and a 3" steel drive shaft.
The Lakewood PN 18020 won't fit without modification.
Anyone else have this problem?
thanks.
Old Oct 1, 2014 | 01:47 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Lakewood Drive Shaft Loop
I installed one years ago. It fit fine with a stock style torque arm and 2.5" driveshaft. The driver side of loop was closer to the driveshaft though..
Later I added a larger driveshaft and a jegster TQ arm and just used a std. loop (not third gen tq arm style) as the jegster arm is much shorter and does not go up far enough to get in the way of std. style loop
If yours is like mine was, the fit to the body/floor is fine but it's too far over to pass. side and may cause larger driveshaft to rub on driver side of loop
Old Oct 1, 2014 | 01:51 AM
Car: 1988 Camaro
Here's a pic of mine
Old Oct 2, 2014 | 01:02 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
I had issues with bmr tubular torque arm
Old Oct 2, 2014 | 09:34 AM
skinny z's Avatar
I guess that would explain why my fabricator cut mine up into pieces. It never did get installed and now I have a box of parts that are pretty much useless. I'll have to build something from scratch.
Old Jul 30, 2016 | 09:57 PM
WickedBowtie's Avatar
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Skinny.....what did you end up doing?
Old Jul 30, 2016 | 10:44 PM
skinny z's Avatar
To tell the truth...nothing.
I had considered fabbing something out of 4" or 5" pipe but having a good look at the torque arm and how it sits with respect to the driveshaft and the exhaust, I doubt I could make it work. I'm considering the Spohn piece (as mentioned in your thread) but haven't made a decision yet.
For what it's worth, it was interference with my custom y-pipe that ended the chances of making the Lakewood unit fit. The big block TA has the Lakewood loop and besides the hassle of having to lift the carpet, it fit without any drama.
So far, tech at the strip hasn't cornered me on it. The rules state:
Driveshaft loop required on all cars running:
13.99 (*8.59) or quicker and utilizing slicks; except vehicles running 11.49 (*7.35) seconds or slower equipped with street tires.
I'm not quicker than 11.49 (yet) and I'm thinking that so far they classify my ET Streets as street tires. If I ever did blow a front u-joint, there's that y-pipe I mentioned to at least keep things reasonably intact.
Old Mar 25, 2019 | 12:10 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Any updates?
Any recent pics anyone have of using the Lakewood loop with an adjustable torque arm and a bigger driveshaft?
Old Mar 26, 2019 | 08:47 AM
skinny z's Avatar
I'm still as far along as I was a couple of years ago. Which is to say nowhere.
But I'm interested in other peoples results too. If there are any.
Old Mar 26, 2019 | 09:27 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Installed mine with a jegster torque arm..
No race application should have a torque arm mounted to the transmission or cross member.
-- Joe
Old Mar 26, 2019 | 03:11 PM
skinny z's Avatar
Joe
I suppose "racing" is subjective and I understand divorcing the torque arm from the transmission extension housing but fixing it to the crossmember seems perfectly reasonable to me. The effects of a long vs short torque arm notwithstanding, what would be the issue otherwise?
Old Mar 27, 2019 | 06:34 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm sorry I didn't elaborate.
I'm assuming a drag race application hence the driveshaft loop, and in making that same assumption would want a short torque arm. The trans mounted torque arm is a big no-no, and the cross member is still too far forward.
Shorter arm mounted farther back provides a better instant center, better hook.
-- Joe
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
