Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
View Poll Results: do hood or leave it alone at 4 inch cowl hood
yes
0%
no
100.00%
Voters: 9. You may not vote on this poll
help me decide on hood or not
Old Jul 11, 2015 | 08:27 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
I wanna add a scoop to the top of my 4 inch cowl hood to let cool air in. I added a photo to show u if I should do it. will be on 84 camaro
Old Jul 11, 2015 | 08:30 AM
Engine: 355
Re: help me decide on hood or not
this is my car currently
Old Jul 14, 2015 | 05:07 AM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Leave it alone. Cowl scoop hood's purpose already is to let cooler air underneath for the air cleaner to draw in. With cowl and the radiator both drawing air in the last thing you need is to pull even more air underneath. For you the name of the game should be sealing off the air cleaner from hot under hood air to the cowl and vent the hot air from the hood through louvers or some other such device. Plus, scoops on top of scoops just looks bad.
Old Jul 14, 2015 | 02:14 PM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
I agree with SC. The cowl hood, especially at 4" tall, is visually very impactful. Adding a scoop into a scoop would just make it all too busy. I recall seeing a 3rd gen in Jackson that had this hood and thinking it was just too much.
http://www.speednik.com/files/2013/0...62117352_n.jpg
Perhaps you could get some additional air movement from some subtle louvers on either side of the cowl?
http://www.ebay.com/itm/Louver-Panel...-/191625526022
Your Camaro is so clean i would hate to see that lost and end up looking like the hood on that Monte Carlo.
Old Jul 14, 2015 | 03:38 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
I built a custom air cleaner for my hood, same as yours, so when its shut it is sealed and sucks air from the vents in the hood. Works awesome! took some time to get it to look nice. I will post a pic if I can find
Old Jul 15, 2015 | 09:28 AM
Engine: 355
ya post pic if you can I had the moroso air pan and it looked tacky to me.
Old Jul 15, 2015 | 09:29 AM
Engine: 355
I agree I thought it would help engine bay temps didn't really think of the visual impact as indepth as I should of
Old Jul 15, 2015 | 09:30 AM
Engine: 355
I thought of the vents but install them in the front of the cowl hood
Old Jul 15, 2015 | 01:26 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Will do. Cant find a pic so have to snap one next time im at the shop. Its off the car due to car getting painted. The hardest part was figuring out how tall/hood clearances.
Is your hood a 4" harwood fiberglass? I called them and they said that in a wind tunnel that the wind goes up the cowl and curls down, bounces off windshield and towards the vents in hood. so the vents are/can be functional.
When I had mine all dialed in,and was totally sealed, air was seriously flowing through the vents, tho I never had any restriction problems. Never had any leaves or junk get up against them neither. Sure would hold a piece of paper up tight tho.
-Dan
Old Jul 15, 2015 | 01:41 PM
Engine: 355
4" glasstek open on backside with no vents
Old Jul 16, 2015 | 02:24 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
putting a goofy looking scoop into the front of it would just add drag and make it look like it belongs in a Japanese cartoon...
the original purpose of the cowl induction hood was to get cool, high pressure air from the base of the windshield into the carburetors on the 69 Z/28 Trans Am race cars without creating a lot of extra drag- it was designed by some of the best aero guys at GM and proven in the wind tunnel and on the race track. but you need to seal things up so that the scoop is isolated from the air that is under the hood or it will do nothing but let air pile up in the engine bay, which creates drag and front end lift while also potentially killing off airflow thru the radiator, which leads to overheating...
here is a factory crossram Z/28 with the air cleaner base that seals up to the cowl induction hood, which is pretty close to what the actual race cars had:
Old Jul 16, 2015 | 04:12 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i agree, it would look ugly. heres a prototype air-pan i made. i've been meaning to re-make it one day. but it actually works good. might give you some ideas?
Old Jul 16, 2015 | 06:24 AM
Engine: 355
do u have measurements on the air pan? the moroso one I have has a small *** filter on it and the pan is mall. I like this better as it uses the 14 inch cleaner
Old Jul 16, 2015 | 09:02 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
its raining here now. i can check later, but im pretty sure i made it 18" wide. i was running a 14x4 filter but just switched to a 14x3 cause i added a plate kit. i only have a 2" cowl. IIRC, the hardest part was making sure it cleared the HEI, but it wasnt that bad. been meaning to copy it and tig weld a nice one.
nice car BTW!!!
Old Jul 16, 2015 | 09:52 AM
Engine: 355
thanks! been a lot of work into that car. its changed a little since photo but nothing drastic
Old Jul 17, 2015 | 06:43 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
yes, mines 18" wide.
i sorta copyied this design. shoulda just bought one?
probably ought to make it to fit your hood, with a good seal.
i sliced some old vacuum or fuel line to seal it after careful trimming.
but this was a good option:
http://www.prosystemsracing.com/cata...92/5233103.htm
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
