Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom Torque Arm Mount anyone??
Old Mar 13, 2016 | 02:39 PM
Drone358's Avatar
Anyone know anywhere we can find a different torque arm mount? Or just buying the stock one just seems like a bad design.
Old Mar 13, 2016 | 03:05 PM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: Custom Torque Arm Mount anyone??
I just ordered a UMI torque arm relocation setup which mounts it to the tranny crossmember. Kinda pricy but I'd rather not bother with more cracked tailshafts.
Old Mar 14, 2016 | 08:22 AM
Drone358's Avatar
Ohh Ok.. I'll have to check them out! Yeah i'll be around the 500hp range so I don't need any of that!
Thank man
Old Mar 14, 2016 | 10:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Buy an aftermarket, tubular, adjustable torque arm. Any brand should have a much better mount attached directly to an aftermarket trans crossmember instead of on the tailshaft housing and may also have a driveshaft loop built into it.
Old May 4, 2016 | 06:18 AM
ceakay's Avatar
Car: '88 Iroc Z. now rebuilding
Engine: 383 cat crank and rods. etc
Transmission: getrag 262 - until it breaks
Axle/Gears: original borg warner 2.77
I'll be looking into making one too, very shortly. I've already done most of my conversion from 700r4 to getrag 262. All that's left now is a torque arm mount and the drive shaft.
Old May 4, 2016 | 06:37 AM
Twin_Turbo's Avatar
Old May 4, 2016 | 09:34 AM
ceakay's Avatar
Nice idea, doubles as a subframe connector, which I also still want to fabricate
Old May 4, 2016 | 10:41 AM
Twin_Turbo's Avatar
I made it so the trans can drop out by just removing the driveshaft and not the tq arm. It's a pretty short arm but I have the geometry dialed in just right. The sliding stub forsn't move hardly at all through suspension travel
Old May 4, 2016 | 01:39 PM
ceakay's Avatar
With dialing in the length, did you physically experiment with different lengths to find the best balance betweeen traction without wheel hop under braking?
Old May 4, 2016 | 02:05 PM
Twin_Turbo's Avatar
It's not the length, it's the height of the pivot. I keps moving it whilst loading and unloading the rear suspension and maintaining proper pinion angle to find the sweet spot. Didn't take that long at all to find the sweet spot
Old May 23, 2016 | 07:23 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Im looking at somthing like that its the BMR track pack
Old Sep 16, 2016 | 09:31 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I have the same thing on mine. It's called a jegster tunnel mount shorty tq arm lol. So easy and out of the way. I tied mine into the tunnel support bars of the 8pt roll bar. Stiff as hell. I wouldn't go with any other tq arm for the very reason of leaving the tq arm on and being able to remove the trans. Had mine out like 10 times and never had to remove the tq arm.
Old Sep 18, 2016 | 10:38 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I've had a crossmember mounted torque arm and have never had to remove the torque arm to remove the transmission. The TA is only held to the crossmember with one bolt and takes 30 seconds to disconnect. Am I missing something?
Old Sep 19, 2016 | 05:44 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
So you are saying you have raised and lowered the pivot point of the torque arm until you no longer have wheel hop under hard braking?
Old Sep 27, 2016 | 01:02 AM
Twin_Turbo's Avatar
Wheek hop under braking? Wheel hop under acceleration is the issue. No, I set the axle on a jacking stand and raised and lowered it through the suspension travel. I simply clamped the upper mount in place and checked the travel on the slider and the change in axle angle near the suspension travel when @ ride height. This way I found the best spot. It really is up poretty high, almost against the floor.
Old Sep 27, 2016 | 09:51 AM
Car: 87 TA clone
The jegster tunnel mount shorty tq arm is only like 2" below the top surface of the tyranny tunnel. So yes having the pivot point up that high is probably correct.
Zflames
Mar 12, 2016 07:10 AM
armybyrd
Mar 9, 2016 10:11 AM
bryanwood74
Mar 9, 2016 09:34 AM
armybyrd
Mar 8, 2016 09:08 AM
