Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Bump stop modifications after LS1 brake upgrade
Old Jun 7, 2020 | 06:52 PM
babyduck's Avatar
What has anyone done after doing the LS1 brake upgrade where you had to cut off the bump stop off the spindle. Now if you turn the wheel to far it hits the caliper. Any help would be appreciated.
Old Jun 7, 2020 | 07:15 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Bump stop modifications after LS1 brake upgrade
Not sure if I saw it here, but I saw where a guy moved the bracket that the bump stop hits to hit in a different spot. I just finished a ls1 swap and haven't gotten that far yet. I will be definitely making something.
Old Jun 20, 2020 | 04:52 PM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
I drilled out the rivets then made my own steering stops and bolted them in place of the originals. I used the originals as a starting point and adjusted the shape and angle for the new brake setup.
Old Jun 20, 2020 | 09:20 PM
babyduck's Avatar
What exactly did you use?
Old Jun 20, 2020 | 09:26 PM
Francis85's Avatar
How do I start my own thread on this site
Old Jun 20, 2020 | 10:13 PM
Engine: 383 SBC
I think I used 12g steel. It’s close to 1/8” thick. The most difficult part for you will be cutting out the shape needed. I was fortunate enough to have access to both material and a band saw at my old job. It can still be done if you can use a cutoff wheel, it’ll just take a while. Otherwise it’s simple, common tools like a vise, hammer, file, drill and bits.
Old Jun 21, 2020 | 07:35 AM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
A photo would be great...
Old Jun 21, 2020 | 11:01 AM
Engine: 383 SBC
sorry, I don’t have any on my phone and I won’t be home for another couple months
Old Jul 7, 2020 | 03:49 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
This is what I did, except I cut part of the old ones off and repositioned the new pieces I welded on.
If you look in the background, you can see one of them in the second picture in this post. It's not quite the same angle as the factory steering-stop.
The downside is that my turning circle is smaller now.
If you keep driving around with your factory steering stops, you will eventually end up with a leak at your brake-hose mounting point.
Old Jul 12, 2020 | 01:17 PM
babyduck's Avatar
I figured it out. Turning to the right, the banjo bolt didn't hit. But turning to the left it did. So what I did was take a bumper support shim and cut a piece off and drilled holes through the existing stop. Bolted it up and works perfect.
Old Jul 15, 2020 | 07:10 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Got pics?
Old Aug 24, 2020 | 05:30 PM
92Z's Avatar
92Z
I saved this pic years ago. Maybe helpful to you.
Old Aug 24, 2020 | 08:09 PM
babyduck's Avatar
Thanks. I finally did about the same thing on the driver's side. The passenger side was fine by a hair
Old Aug 25, 2020 | 05:25 PM
Engine: TBI 305
Does the steering-stop still make contact with the caliper, or does it hit the bracket?
Because if it hits the caliper, it will push the pistons in on really tight turns, and reduce your braking performance for the next couple of pedal applications.
I noticed this in parking lots shortly after installing the kit on my car (before I modified the stop).
Ex: I'd back out of a tight parking space, and the next time I stepped on the brake, the pedal went to the floor. It took me awhile to figure out what was going on.
Old Dec 2, 2020 | 10:52 AM
91banditt2's Avatar
Engine: 5.7 HSR
Back from the dead, need ideas for a steering stop.
Old Dec 2, 2020 | 11:45 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the picture above looks like it would work.
Old Dec 2, 2020 | 01:42 PM
91banditt2's Avatar
Engine: 5.7 HSR
Think it's hitting the caliper bracket?
91vaneZ
Brakes
May 21, 2020 05:35 AM
513camarors91
LSX and LTX Parts
Feb 23, 2012 01:28 PM
88fastgta
Aug 14, 2011 05:37 PM
anthony714
Brakes
Sep 23, 2006 09:53 PM
CAMAROJOKESTER
Brakes
Jun 11, 2006 10:16 AM
