FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Factory Performance
Old Nov 9, 2006 | 08:54 AM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Factory Performance
anybody posted any threads or put the factory quarter mile times/MPH before for all models?
my 85 IROC has its motor out of it for now and i may be getting a L98 from an 87 so i'd like to know what i can expect out of it.
be a good sticky if we got all of the performance figures for all years and all models(base, berlinetta, RS, Z28, IROC-Z28) and (Base, Formula, Trans Am, GTA, TTA).
Old Dec 1, 2006 | 09:56 AM
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
the 87 L98 cars IIRC ran somthing in the high 14s factory. other than that I'm not sure. cept the TTA (89 MY, as there was a V8 TTA in the early 80s) it ran slightly faster, 275HP and all.
Old Dec 7, 2006 | 11:29 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
My 88 IROC with the L98 tottaly stock ran 14.9 @ 89.6 MPH. They were probably faster from the factory but mine has around a 190,000 miles and still running strong.
Old Mar 22, 2007 | 03:08 PM
Dragonsys's Avatar
Car: 02 TransAm
Re: Factory Performance
My GTA with a L98 ran a 15.05 @ 71
Only mod at the time was a bad tranny
Old Apr 21, 2007 | 09:36 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Wow, im impressed it ran that fast full stock......Very good....What are some more pure stock times??
Old Apr 22, 2007 | 09:06 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
A friend from work just bought a 1988 Trans am with the l98 and 700r4 the only difference between mine and his is he has a 3.27 rear end and mine has a 2.77 and his ran 14.4. I think I'm going to get him soon though, I got 3.27 gears and carrier and I'm picking up a lt1 modified intake today.
Old Apr 22, 2007 | 04:36 PM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
14.10 at about 99mph with my 120k mile Formula. Only real mods are cheap cold air intake,air foil, no cats, and Flowmaster catback. I did some of the free mods and removed a little weight too. This sucker pulls pretty hard for what it is! I don't think 13's are oughtta the question with a little more tuning.
Old Apr 22, 2007 | 08:23 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My 85 iroc has a 305 TPI from a 88 iroc in it. In the future i plan on putting the 85 TPI back in it. I know the 85 motor has 215 hp over the 88's 195 but will i see any improvement in the quarter mile time or not? If so how much?
My 85 iroc currently has a 305 TPI from an 88 iroc in it. In the future i plan on putting a 305 TPI from an 85 back in. I know the 85 motor has 215 hp compared to the 88's 195 but will i see any difference in the quarter mile time? If so how much?
Old Apr 23, 2007 | 04:25 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
With the 85 motor you will notice a slight loss in low end torque. But on the other hand, You'll notice more over all improvement in the mid/ top range. The 88 motor should be outta breath by about 4,500 while the 85 is capable of higher revs. stock for stock the 85 will outrun the peanut cammed 88 setup by at least a couple 1/10's in the quarter. The 85 motor will also respond better to simple mods like, intake porting, exhaust work, etc. It has a decent sized cam for a 305. It can get some breathing done if You open up a few restriction's.
Old Apr 26, 2007 | 04:28 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Just for clarification, those '88 specs on the LB9 TPI are from an auto tranny equipped Camaro. If only the donor had a 5-spd stick, then she didn't get a peanut cam but a sweeter cam resulting in an LB9 with 220hp & 290trq (both greater than the '85 auto only equipped LB9).
Old May 5, 2007 | 01:46 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I went to the track last night just to get some more base lines before the gears nd intake go on. My first run was a 15.088 @ 87.83 2nd 15.084 @ 87.45 3rd 14.97 @ 88.53. Then I took about an hour break to let the car cool down and let the sun set and my final run was a 14.78 @ 91.64. All these times are from a stock L98 car. I was impressed but a friend I went with has a stock SRT-4 and was running 14.1 all night
Old May 5, 2007 | 10:43 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
That is so weird my LO3 had a better MPH than your car, but not as good a ET..Except your last run....You had some great runs...Look forward to seeing your times after the gear, and intake.Good Luck, Tom
Old May 9, 2007 | 11:56 AM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
my 91 rs 305 5 speed 16.77 1/4 @ 88.7 gtech rates my car at 111hp and 166trq 0-60 in 8.7sec..... the car has 20in rims on it so ill have to get a run with the stockers. I only made one pass the car weights 3480 with me system and 20s
Old May 9, 2007 | 05:03 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
my 84 berlineta with the l69 and 700r4 goes 14.5 smokin rr thru 60 foot mark bone stock with 3.42 gears
Old May 9, 2007 | 06:28 PM
manifoldsrme's Avatar
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
Bone stock 85 IROC here and it will run 15.20's all day long. With something as simple as a gear change an 85 305 TPI IROC will run with if not a little better than a stock 350 IROC from later years. I run drag radials all the time otherwise I just blow the rear tires off mine on the street.
Old May 12, 2007 | 01:18 AM
canadian250's Avatar
Car: 1985 WS6 T/A
Engine: LB9 305 TPI
Axle/Gears: 9bolt 3:27
Times in sig with stock Goodyear gatorbacks.
Old May 14, 2007 | 12:54 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
R/T ... .172
60' ... 2.201
1/8 ... 9.962
MPH ... 68.18
1000 ... 13.016
1/4 ... 15.597
MPH ... 87.33
'85 Camaro Z28 TPI 305 (139,xxx), 700r4, 3.23 posi,
-rear seat delete, A/C delete, AIR delete, throttle body coolant bypass, descreened MAF, and removed intake baffles.
It's still in need of a proper tune up as well as some timing adjustments. I may be able to shave another tenth off my time as my best 60' was 2.177, my best 1000' was 12.933 and on my fastest run I manually shifted at 5,000 RPM instead of 4,500 RPM.
Old May 14, 2007 | 07:18 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Originally Posted by DBLTKE
R/T ... .172
60' ... 2.201
1/8 ... 9.962
MPH ... 68.18
1000 ... 13.016
1/4 ... 15.597
MPH ... 87.33
I have almost the same mods as you....I ran 88 MPH, 15.3 et, with a TBI...Lost the back seat, ac, smog....same gear too...
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
