FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
stock rim size?
Old Sep 28, 2006 | 07:51 AM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
stock rim size?
Does anybody know what the dimensions are for stock 87 iroc wheels? Backspacing, rim width and offset. Thank you
Old Sep 29, 2006 | 03:34 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Old Sep 29, 2006 | 03:17 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
The only reason why I asked, navycm, was because I wanted to buy these cragar 397 series from summit, but then I saw all these different rim sizes and I don't know which one would fit now. could you help me by seeing on summitracing which 397 series rim would fit my car. I feel like an idiot.
Old Sep 29, 2006 | 11:30 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Your going to need to know backspacing. Take the wheel off and lay it on a flat surface w/ the back side(the side that faces the brakes) facing up. Then take a straight edge and lay it across the wheel and measure down to the mounting pad. You may have to deflat the tire to do this. That measurement is your backspacing.
Old Oct 1, 2006 | 04:51 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
I found out my backspace today, it's 4.5 inches. Thank you.
Old Jul 19, 2007 | 07:58 PM
IROC-Z_Racing's Avatar
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Re: stock rim size?
I'm tired of looking all over the place, what is the freakin bolt pattern of a 89 IROC Camaro? The reason I ask is that I've found 315 tires and I'm working on a custom rim for them and need to know what the bolt pattern is and backspacing. Thanks!
- IROC-Z Racing
Old Jul 19, 2007 | 09:32 PM
Stephen's Avatar
Car: 87 GTA
Re: stock rim size?
A 315 won't fit under a 3rd gen wheel well anyways. It'll stick out.It'll hit your LCAs, inner sheet metal. Lots of stuff in the way, unless you are planning on back-halfing the car, for them to fit.
Old Jul 19, 2007 | 09:44 PM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Re: stock rim size?
I had bought an 86 IROC in the past that already had 315's on there with a stock body and they did not stick out, the were flush with the sides of the body.
But anyways what is the stock bolt pattern and backspacing for an 89 IROC?
Thank you!
Old Jul 19, 2007 | 09:55 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: stock rim size?
Here is a link in the Tech section of TGO on wheels and wheel fitment;
http://www.skulte.com/adapterfaq.html
Old Jul 20, 2007 | 06:34 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: stock rim size?
I don't see how 315's could fit without a deeper backspace, minitubs, or wheel spacers. I just put 275/60/r15s on my 89. The tires rubbed on the body until I beat the inner fender in with an eight pound sledge. Even now i only have about 3/4" clearance. 315's are 4cm wider or ~1.5" wider.
Old Jul 20, 2007 | 07:07 PM
Stephen's Avatar
Car: 87 GTA
Re: stock rim size?
On my 92 RS, I had BFG 295/50R16's on my stock 16"x8"s, and never rubbed inner or outer. The tire fit fine. No cupping. a 9" wide wheel might have been better, but I had no problems.
A 275/60...That is a tall tire and has a section width of 11". I bet you had a lot less BS. That much section width, on a tall that tall, I'm not real surprised you had rubbing issues. The higher you get in the wheel well, the narrower it gets.
Old Jul 20, 2007 | 08:34 PM
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Re: stock rim size?
These tires that I have are Goodyear F1 GS D3 315/35ZR17
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
toronto formula
Nov 10, 2015 06:17 AM
Randomtask2
Aug 13, 2015 01:57 AM
Exxon Limited
Aug 9, 2015 08:13 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
