quad driver module
Old Apr 19, 2003 | 10:16 AM
chainbearer's Avatar
quad driver module
what the heck is a quad driver module and where is it at? I need to locate it and replace, but I have no idea where to start looking.
thanks for any help
Old Apr 19, 2003 | 09:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
A QDM (Quad Driver Module) is a component inside the ECM (Electronic Control Module). The ECM is what controls the engine functions. I don't know how you came to the conclusion that you need a new QDM, but if one is bad, you have to replace the ECM. Also, if you really do have a bad QDM, then more than likely a component that the QDM controls, failed, killing the QDM. Could be a shorted TCC Solenoid, shorted EGR solenoid, etc...
Old Apr 20, 2003 | 11:49 AM
the 54 code has been thrown by my computer several times. I have replaced the fuel pump relay and I am getting a fuel pressure test on monday. if my pressure is good, I will know the only other thing it can be is the qdm because of the 54 code.
thanks for any help.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
sbrandon
Sep 9, 2015 07:31 AM
rsrookie
Sep 5, 2015 07:08 PM
