Are these common?
Old Feb 18, 2004 | 09:26 AM
HawkFanatic's Avatar
Car: 99 T/A Firehawk, 1991 Formula
Engine: LS-1, LB9
Transmission: M6, M5
Axle/Gears: 3.42, 3.42
Are these common?
Hello all!
I have a dream to build a really bad assed 3rd gen one day, and was looking for one particular car..
A 91-92 White Formula 350 WS6 5 speed hard top.
First, did they make this combo, and second, is it an unusual combo?
thanks for your info...
Old Feb 18, 2004 | 11:24 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
The 350 (L98) was never available with a 5spd from the factory. It was only offered with an automatic.
The 305 was available with a 5spd.
I think you will be able to find the car you described, except for the transmission.
FYI all thirdgen Formulas had WS6.
Old Feb 18, 2004 | 12:51 PM
cdartz's Avatar
The easiest way for you to get what you want is to buy a 305 TPI 5-speed car. Then swap the 305 for a 350. The only parts you'll have to change are the block, heads, injectors, and PROM.
Old Feb 18, 2004 | 03:10 PM
Stevo's Avatar
Car: Pair of 92 Z28s
um wouldnt a more easier way be to buy a 350 car and swap the 700R4 auto for a 5 speed..?
trannys go for less then engines i would think
Old Feb 18, 2004 | 03:54 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i would agree with you, except for the fact that a stock 5 speed can't handle a 350... need to put a different tranny in...
Old Feb 18, 2004 | 07:34 PM
Stevo's Avatar
well under normal driving the T5 would be ok i think (just because ive read that a few times at this site lol) but ya if ur a little hard sometimes on the car...which who isant sometimes then ya ud need sometin else....
Old Feb 18, 2004 | 08:19 PM
ershealy's Avatar
Car: 88 TBI Formula, 98 LS1 TA, 77 400 T
Some people have had trouble keeping the 305 from breaking the 5 speed. All depends on how you drive I guess.
Old Feb 18, 2004 | 08:20 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well man as far as a 5 spd goes you'll have to get a beefy one to handle the 350
Old Feb 19, 2004 | 10:54 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Get a 6 speed from a 4th gen
John
Old Feb 19, 2004 | 06:49 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yes, the T5 from 82-87 handled 280lb/ft max and the World Class T5 (88-92) took 305lb/ft max.
The stock 305 TPI with the non-peanut cam puts out 220hp and 300lb/ft torque... that's just 5 less than the WC.
A 350 must make at least 5lb/ft more than the 305!
But... a T56 from a 4th gen can take 450lb/ft max! And that's just a great mod anyway!
Old Feb 19, 2004 | 08:23 PM
ershealy's Avatar
The six speed swap is rather involved right? I mean it is more than just a bolt in affair right?
Old Feb 19, 2004 | 10:05 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
There are many posts about it I believe, and I do think it's kinda involved.
I know the crossmember needs to be changed/modified, there isn't a speedo cable hookup... so unless you have an electric speedo already, you need a speed sending unit (about $100)
The driveshaft might be different... but I'd check on that one!
Old Feb 23, 2004 | 12:57 PM
Engine: LS-1, LB9
Okay, so the drivetrain is optional. I was planning on swapping in a MN6 anyway...
How hard is it to find the White Hardtop? any idea on how many hardtops were made in 91-92??
Old Feb 23, 2004 | 02:34 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I have seen many Firebirds that are white... mostly GTAs. I have seen a few white Formulas around here, most always with gold trim/decals.
Check ebay and see how many are being sold... and how much they are going for. That's usually a little more than they are worth, but good for a ballpark figure.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
FormulaEngland
Sep 30, 2015 01:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
