Rear View Mirror Options
Old May 12, 2004 | 11:39 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Alright, first and most important question. Is the autodimming rear view mirror the exact same for the Camaro and Firebird, right down to the color of the lettering?
Second: What mirror options were available and on what years? Here's what I know.
Standard mirror - 82-92
Dual map light mirror - 8?-??
Auto dimming mirror - 87?
I've seen or heard somewhere that some of the GTA's had a rear view mirror that was remotely controlled????
Old May 12, 2004 | 06:44 PM
labrat's Avatar
Car: 87 IROC-Z
Transmission: automatic
Really don't know if the auto diming is different between a Camaro and a Firebird. My guess is, it is the same.
The auto dim mirror was only available in 86-87 in Camaro, probably the same for Firebird. I have yet to see one that works. But some of the low mileage cars on this board may still work.
Scott?
The dual map light mirror option was available from 89-92
Old May 12, 2004 | 10:29 PM
Guest
Guest
Posts: n/a
My 86 TA has one. I also picked up a spare. Both work. My car has 156,000 miles on it, so... I dunno about mileage being any problem.
Old May 13, 2004 | 08:11 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
madmax,
Can you post a pic of yours? Does it have white lettering?
Old May 13, 2004 | 09:51 AM
labrat's Avatar
Car: 87 IROC-Z
Ya, mileage probably isn't an issue. Maybe just luck. They seem to be pretty unreliable though.
Old May 13, 2004 | 10:11 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Mine did not work when I got it with 6300 miles.
2 years ago at the Camaro SuperFest, somebody gave me one from an 88. The shape is slightly different and it to didn't work.
I took the motor from that one and soldered it onto my board and now mine works.
The age is probably more a factor than the mileage. They were not very reliable then and are not very quiet either. Mine is turned off right now due to the whining noise of the motor when it activates. It startles you if the tunes aren't loud enough to override it.
Also, I believe they were available beyond 87. I think the replacement I got was from an 88. It could've been from an 86, but I thought it was newer, not older.
Old May 13, 2004 | 11:00 AM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
My invoice for my 87GTA has this for the mirror,
DD8 Mirror-rearview automatic tilt
Is this what you mean by "auto dim"?
Plus, I don't know if mine works right now(no engine yet).
Laters,
Conrad
Old May 13, 2004 | 11:06 AM
scottmoyer's Avatar
If you have battery power to the car, you can test the mirror easily. block the sensor on the windshield side of the mirror and move a flashlight across the sensor on the face of the mirror. It will take a second or two for it to activate, but you'll hear it if it works.
Old May 13, 2004 | 12:45 PM
Guest
Guest
Posts: n/a
Pretty sure the lettering is white. I'll take a pic of it later.
Old May 13, 2004 | 02:35 PM
labrat's Avatar
Car: 87 IROC-Z
Scott,
The Camaro White Book shows it available in 86 and 87. only
So I,m pretty sure it was discontinued after 87
Old May 13, 2004 | 11:41 PM
Guest
Guest
Posts: n/a
Later is going to be alot later. I forgot I dont have the car, not sure when I am getting it back.
Old May 14, 2004 | 08:21 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I personally went with an auto dimming mirror from a 90 Riviera, its shape is almost identical to the standard "non-autodimming" mirror, but the cool thing is its silent . It uses Liquid Crystal to darken. Besides no one ever notices it... not like my car is stock.
Green wire - Backup lights
Black wire - Ground
I think it was red - switched power
John
Old May 14, 2004 | 04:06 PM
scottmoyer's Avatar
Originally posted by labrat
Scott,
You're right. I just did some additional checking and couldn't find the mirror on the 88's or 89s. The other mirrors that I got must've been 86 then.
Old May 15, 2004 | 10:38 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I got one of those on my 86 IROC Z, but never checked to see if it worked. I dont drive the 86 IROC Z any more either so I have to see if it works.
Kevin
1992 Trans Am
May 10, 2023 07:19 PM
draco
Oct 4, 2015 09:25 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
