A Weird freckish engine
Old Aug 2, 2001 | 08:56 AM
Impossie's Avatar
I have a 1985 trans am, with a lg4 (305)v8 in it and last week my friend let me G-tech my car because I thought that my car had some extra boom in it. Well I G-Teched it and I ran a 16.05 at 89.6mph with 4065lb!total weight of my car, (I had all seats full with half tank of gas and a butt load of tools and skateboards in the back). I went to www.corral.net and typed in the times from my car and it calculated that my car has 233hp. The only thing that I have in my car is a K & N open element air filter. The rest is all bone stock. Why is my engine a Freck?
Old Aug 2, 2001 | 09:36 AM
Drew's Avatar
Its not... Never trust a $140 gadget and calculations. Throw it on a dyno or run it at the dragstrip. The LG4 is nowhere close to 233hp.
Old Aug 2, 2001 | 09:55 AM
Impossie's Avatar
I went and did the calculations on many different internet sites and they all told me the same amount.but to make sure the g-tech was right ,I just got back from the auto hobby shop on the base. And they put it on a wheelie thing and when you are in the driver seat you look out the window and you can read the screen and it has a needle and it was on about 200. And yes that does mean the g-tech was off , but not 70 hp.....do you think that there is a different engine in the car then what the Vin says?
Old Aug 2, 2001 | 11:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I suspect your estimate of the weight is off, which GREATLY affects the calculation of HP.
My 91 GTA, with no driver and minimal gas weighs 3,410 lbs. This has been confirmed within +/- 20 lbs many times and remember that a GTA tends to be the heaviest of all the 3rd Gen F-bodies. A full tank of gas weighs about 100 lbs.
Assuming your car weighs close to mine, with a half tank of gas your car should weigh no more than 3,450 lbs. Add your own weight and REMOVE ALL THE TOOLS and do the test again. Assuming you weigh 200 lbs, you are saying your tools weighs over 400 lbs.
Old Aug 2, 2001 | 04:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's no way an LG4 has close to 200 RWHP either.
Old Aug 2, 2001 | 07:00 PM
Impossie's Avatar
ok, i got some good news. I took the car down to the hobby shop and i told them i wanted to see what kind of horsepower i am getting. They said that they would "dyno"it (i have no clue what that is but they put my car on some huge rollers and they started to drive it ). $60 LATER!, they said that my 1985 lg4 T/A has 213hp. Larry was shocked and said that i have a gm freak. i think it is a lg4 because the numbers say so, but it only says 305 under the engine. is my car a Freak? greg
Old Aug 2, 2001 | 07:34 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Whats the stock hp rating for his 305?
Old Aug 2, 2001 | 08:31 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
stock is 155hp. I suspect that your motor is not stock
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old Aug 2, 2001 | 10:31 PM
Impossie's Avatar
thats what i figured, thank you all for your time and help. later greg "the freak car"
Old Aug 4, 2001 | 01:03 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
What base are you stationed at?
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
Cleotiz
Jan 6, 2018 08:56 PM
EFR2000
Aug 18, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
