1990 Iroc
Old Mar 28, 2008 | 08:02 AM
baron2's Avatar
1990 Iroc
Can anyone tell me how many 1990 Iroc were made with a 5.7L, 5 speed and with t-tops? Thanks.
Old Mar 28, 2008 | 09:42 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Re: 1990 Iroc
None. The 5.7 was only available with a automatic trans.from GM. If you have a 5 speed its a conversion.
Old Mar 28, 2008 | 11:10 AM
Re: 1990 Iroc
Zero
No 350 / 5-speed combos in these cars sold to the public, EVER.
People put that together all the time though, but it didn't come like that.
Old Mar 28, 2008 | 11:22 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: 1990 Iroc
3rd gen. Camaros, Firebirds/Trans Ams/Formulas, with the 5.7L, never had this engine with the 5 speed (T5) behind it. So, if someone is trying to sell one saying it is all original, you now know the deal.
Old Apr 28, 2008 | 12:46 PM
laidbackmac's Avatar
Re: 1990 Iroc
Just to add to that, for 1990 there were no T-top IROC 350's. The only way you could have the 350 was as a coupe with the automatic
Old Apr 28, 2008 | 03:40 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Re: 1990 Iroc
^^^ That's ONLY true for 90...87-89 had t-tops available with the 350...
Old Apr 28, 2008 | 04:18 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: 1990 Iroc
yea my car has the 5.7 and ttops
Old Apr 28, 2008 | 08:32 PM
baron2's Avatar
Re: 1990 Iroc
I have run the engine code...it is a 305. Now I have a new question. With the following RPO codes, can anyone tell me if this is a 1LE?
LB9, J65, G92, UU8, N10, KC4, FE2, GU6, G80, Z28, 1AY. Thanks
Old Apr 29, 2008 | 02:09 AM
LaxStreetRacer's Avatar
Car: 91 Z28
Re: 1990 Iroc
Nope, not a 1LE. The RPO for a 1LE is just that, 1LE. That looks like a pretty decentently optioned ride though(LB9, aluminum driveshaft, performance gears, dual cats...).
Old Apr 29, 2008 | 11:12 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: 1990 Iroc
If that's your car, baron2, with TPI, a 5-speed, t-tops, 4-wheel discs, performance axle ratio, dual cats, etc., it definitely looks like an excellent one. Or if it's one you're looking at buying, I'd say go for it.
Like LaxStreetRacer said, the code for 1LE is 1LE. And the code for an aluminum drive shaft is JG1.
Old Apr 29, 2008 | 07:22 PM
Car: 91 Z28
Re: 1990 Iroc
Doh, I must be getting rusty. I thought J65 was aluminum driveshaft, or is that the code for the space saver aluminum spare?
Old Apr 30, 2008 | 10:21 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: 1990 Iroc
RPO J65 gets you front and rear disk brakes.
RPO JG1 is the aluminum drive shaft.
RPO N64 is the aluminum space saver spare.
RPO N65 is the steel space saver tire.
Old Apr 30, 2008 | 10:50 AM
Slouch's Avatar
Re: 1990 Iroc
I wonder if you could have made a special order for the 350/T5?
Old Apr 30, 2008 | 11:43 PM
Axle/Gears: 3.08
Re: 1990 Iroc
No. Chevrolet offered very specific packages that even the dealers had to conform too. Even the 1LE, B4C and G92 packages were very specific and followed certain rules.
I have never seen of even heard of a factory built special order for the 350/5spd combination that was ever available through a dealership/customer order. Believe me, many a customer would have tried resulting in many documanted cases of this occuring. It never has. I would love to be proven wrong, believe me. That would be pretty cool.
It also would have raised warrentee issues as well as that's one of the reasons that the stronger 350 wasn't mated to 5 speed.
Old Aug 14, 2008 | 11:29 AM
Re: 1990 Iroc
Yeah I believe they changed it for 1990 due to increasing output from the 5.7 and the fact that the t-top cars had less structural rigidity. Not sure about the 91/92 cars tho.
Frozer!!!
Jan 19, 2024 04:55 PM
Djmathis123
Sep 29, 2015 01:36 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
Dialed_In
Aug 20, 2015 01:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
