Where are the Weird/Cool model Camaros!?!?!
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
I've seen all of these cool Fire Chicken versions. Trojan, Notchback, SLP FireHawk, Bandit Edition, And others.
Didn't Chevrolet Get with anyone to do this kind of stuff. The only one I know about is the possible 3 that are out there that are heritage edition cars with LT1s and 6Spds.
Wasn't there any cool Camaros that you could buy?
Chevrolet did it in the late 60s with Yenko. What Happend?
I probably just don't know about them because they are REALLY Rare, and never seen.
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Re: Where are the Weird/Cool model Camaros!?!?!
Good point, never thought of that. I disagree though on no cool Camaros - I see plenty in this forum.
Joel Rosen of Motion Performance created a few IROC-Z cars with wide body kits, but they aren't anything as each car was built to the customers' specs, not his. There were only a few made though. Also, the Tojan was made on both Firebird and Camaro platforms. There were others, but I'm drawing a blank on the names.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I prefer the Firebird Formula over any Chevy Camaro model, but that is just me. I also believe the interiors are far more cleaner than the camaros. Andrew
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
chevy didnt get together with yenko Yenko had a chevy dealership and just used the Central Office Production Order way of getting camaros with 427s, it wasnt some team up to make fast cars...
Car: 89 Formula
Transmission: TH 700R4
I suspect its because Chevy has the Corvette. So GM let Pontiac have many special editions of Firebirds.
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Honestly Chevrolet did some test cars but they never made it into production like in 1983 they had a turbo 4.3 V8 they considered but never materialized.
The Togan sister car from the Camaro was the Carello, it was quite different than the Togan.
I think one of the things is Pontiac always wanted a Sports car, and when they were denied this from Chevrolet they treated the Firebird more like a Sports car than Chevy did. Although they were made on the same platform the concept of making the Pontiac more Sporty was always in the back of their mind. As the Third gen matured this came into realization and companies (GM included) decided to make some special cars which really highlighted this fact. SLP teamed up with GM to release the SLP Headers and Siamesed Runners, which was available over the counter to people or installed by a dealership. Then SLP got serious and decided they could create the Ultimate Sprts car. They based it on the Formula more than likely because it was the lightest of the Firebirds and it was more Aero friendly than the Camaro. Thus the Firehawk was born. I suspect that Chevrolet was intending the Heritage edition Camaros to be of a similar vein with some of the preliminary specs which were released. Ultimately I suspect that Ed Hamburger decided not to do the Camaro as the Tests required to do the Firebird almost caused SLP to go int bankrupcy, a similar test on the Camaro could have been catestrophic. In short the Heritage Edition became a Sticker package in the end...
How true this is I really do not know but it really makes sence to what I have read and other information.
Camaro has the 1LE cars so your not all alone over there with nothing special. That and T-tops were more available on the Camaro than Firebird with the L98, so its not like you have nothing just not as much...
John
John
Both were rolling ogres. Neither were released by GM.
The Camaro had the Evolution kit too, but that wasn't from the factory either.
There were 1LE Firebirds too. T-tops being more present in L98 Camaros isn't all that cool, but that's my opinion. Hardtop>T-top imo
Car: 89 Formula
don't forget the protoype of the 4.3L TURBO V6--maybe 88 or 89? They tried it with a 5 speed to but I think it broke
Thats not what your thinking of is it okfoz?
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
started searching macho and came up with some cool stuff
Check this site out...
http://www.omnipotent-goku.com/iroc/gallery/album05
Crazy stuff on this site..
Car: 1984 Camaro Z28
Engine: 350 from an elcamino
Transmission: stock t-5
Axle/Gears: 10 bolt 3.73 limited slip
theres also the banks twin turbo third gens, or are we only talking about factory cars?
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
More or less cars that you could buy. Cars that were sent to shops to be outfitted different that you could order. Things like that. I've never seen a Banks TT Camaro. Off to search for pics....
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I disagree with okfos the 4.3 turbo did materialize just not in an Fbody most forget about the GMC Cyclone and Typhoon
Engine: 350 4bbl
right I got that as stated in my previous post I was just stating that it did make it sucessfully I just wonder why it was never stuffed into a third gen
im sure ill get flamed for bringing this up,,but i will again....i consider my 84 ZF sport coupe a "specialty' camaro ,at least as much as the previously mentioned motion cars etc....From what i have gathered each where different but shared a couple common traits..My car is documented with build sheet and original invoice. They state being shipped from the factory straight to ASC where it received a moonroof , a woodgrian dash upgrade (depending on how you look at it) and exterior emblems and striping...My car is also "odd" in that is is a radio delete car with a 305 5 speed and a 342 limited slip rear..I can only think that is was order with some sort of performance in mind ,,all be it low performance by todays standards...My car also has a fiberglass z28 style hood with the functional flapps and air cleaner like a L69 z28 would have...I have no proof of these being installed by ASC but the hood appears to have been only red and the rest of my car is original paint as of now...i do agree and understand it doesnt have its own specific factory RPO code,,but to my knowledge Mecham trans ams do not either..hope that lets you know there are some "special" camaros out there
Engine: 350 4bbl
Where can I pick up one of those hoods for my 82 Z, I have the same thing just non functional flaps
Linson
Aug 21, 2015 02:12 PM
