WTB, GM antitheft decals or a pic of one
Old Jul 20, 2008 | 06:24 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
the ainttheft decals on the lower part of the windows that GM had on VATS cars......anyone know how i can find a set of them???
or maybe a pic of one so i can see if my sticker guy can make a set
Old Jul 20, 2008 | 09:42 PM
RPM WOT L 98's Avatar
Re: WTB, GM antitheft decals or a pic of one
Still available from the dealer. At least the later version that says "vehicle and radio anti-theft systems" Same decal just has the extra "radio" in it.
Old Jul 21, 2008 | 10:15 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I had my local vinyl sign shop make me up a set for under $5 in about 5 minutes. Just showed him my old ones and he did theem real quick. Looks brand new.
Sorrry no pic of mine but I am sure someone here can do that part for you.
Old Jul 21, 2008 | 07:55 PM
89RS_82Z's Avatar
COOL.............*BUMP* for pics
Old Jul 21, 2008 | 09:22 PM
AsphaltAssalter's Avatar
Car: 92 Camaro
Here ya go buddy, it's a little wore out but this is what came on my 92
Old Jul 22, 2008 | 09:54 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Here's a sharp one from my '89 (same year).
PM me and I'll send you a hi-res version (3072 x 979).
Old Jul 22, 2008 | 01:43 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
So what is the story on the system? I don't believe it was available in 88 - that is unless one considers an ignition lock a theft system.
Old Jul 22, 2008 | 05:26 PM
89RS_82Z's Avatar
its the VATS key, the key with the chip in it
BTW ,AsphaltAssalter & Iroctopless
Old Jul 24, 2008 | 02:15 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
GTA's starting in 1988 had VATS, and ALL other F-bodies starting in 1989 had the VATS... I have considered adding it to my Yellow car but not gone to far with it...
John
Old Jul 24, 2008 | 02:34 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
My '91 Z28 also has the VIN etched into the rear glass. That may have been done by the dealership though. Don't recall exactly now.
Bill
Old Jul 24, 2008 | 03:40 PM
okfoz's Avatar
The etching of the windows is a Sales gimmick thats suposed to reduce theft... In reality I think all it does is cost the consumer money, there is no way to actually tell that doing that reduces theft. When I bought my rainier the dealer tried pushing it on me to have the antitheft things placed on the car...
Ultimately I guess they could point to statisitcs but if I was a thief I would not go around inspecting the windows before I stole a car... THe DECALS on the windows however may help as it would indicate to any would be thief that this car may be more difficult to steal than the one next to it.
John
Old Jul 24, 2008 | 07:07 PM
Burnout91's Avatar
Engine: Modded L98
John
I suppose anything is possible if you.....
I was just adding info; the etching was in place when I first saw the car. Not a salesperson tack-on. You, are adding an opinion .
Call your , raise you a dollar.
P.S.: The etching came with an additional window decal.
Bill
Old Jul 24, 2008 | 08:01 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
When i bought my iroc in 1985 my insurance company (AAA) etched all my windows and t-tops free of charge and then reduced my premium by a small percentage.
Old Jul 24, 2008 | 10:04 PM
FrankieRider2's Avatar
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
As John mentioned, some 1988 GTAs came with VATS (not all) and had the above decal affixed to both side windows at the bottom above the weatherstrip. GTAs also had a matching radio anti-theft decal as well, as the cars featured the Delco-Loc radio system.
Old Jul 25, 2008 | 01:57 PM
Axle/Gears: 3.08
VATS incorparates a simple resistor in the key (1 of about 15 different resister values used). No smart chip used here. The key's resistance is paired with the resistance the ignition is looking more. If they match, then the car will start.
More info is right here . . . https://www.thirdgen.org/vats_passkey_system
Old May 28, 2009 | 08:29 PM
89RS_82Z's Avatar
BUMP anyone got any ideas on getting one made, i know its not 100% correct but what about a die cut vinyl sticker
Old May 29, 2009 | 08:46 AM
Axle/Gears: Posi
Just go to your sign guy and ask him to make you a copy of the sticker poosted above with the glue on the front so you can install it from the inside.
Old May 29, 2009 | 10:41 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Bill
VIN etching on the windows or T-tops was never done by the factory, that's a fact, not an opinion.
Hotrodboba400
Dec 10, 2019 07:07 PM
pimprs
Sep 10, 2015 03:34 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
