87 z28 vs iroc-z28 differences?
Car: 87 Camaro Z28
Engine: 355
I have an 87 Camaro. It has a 305 with the quadjet carb. Auto trans. The car was repainted and has z28 trim. So so I always thought it was a z28 yet i cant be sure of the paint and stickers since it wasnt factory. How ever when i put the vin into any carfax report type services it tells me it is an iroc-z28. So i went to the 87 camaro tech data page on this site and found the two to have the exact same drivetrains.
So what is the differences in the two models and how can i tell for sure what mine is.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: 87 z28 vs iroc-z28 differences?
well first of check for wonderbar, check for 16inch rims, hood louvers, but if thats your car in your avatar looks to be a regular z28, you could also check center console, and see if rpo code sheet is there thats your best bet
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
On the 16" wheels check the driver's door sticker to see if it has this for tire size(that is if it's still there given the repaint). In using the VIN to research a Camaro it's problematic given the Z28 is technically an option on the Sport Coupe and the IROC and option for the Z28 (the Berlinetta had the only unique VIN designator). If there is a SPID in your console make sure it's VIN matches your car's.
Car: 87 Camaro Z28
Engine: 355
It does have the 15x7 wheels. But in 87 there was a z28, iroc-z28, and the iroc. So i know that the iroc has 16' wheels. But what is unique to the iroc-z28 that makes it different from the regular z28 or regular iroc.
mine has
15' wheels
louvers in the hood
ground effects kit
85 mph speedometer that cam on all carb irocs in 87
so it is deffently not an iroc but it is still up in the air wether its the z28 or iroc-z28
mine has
15' wheels
louvers in the hood
ground effects kit
mine has
15' wheels
louvers in the hood
ground effects kit
mine has
15' wheels
louvers in the hood
ground effects kit
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That was confusing, I think what you are trying to say is you could buy a Z28 or a Z28/IROC-Z.
The IROC included in 1987:
16" Wheels
245-50R16 Tires - Look on the door jamb decal
Wonderbar
some enhanced suspension parts
Fog-lamps - might have been deletable
(did the Z28 (non-IROC) in 1987 get the grid style Tailights???)
John
16" Wheels
Wonderbar
John
Car: Many
Engine: Several
Transmission: Automatics
16" Wheels
Wonderbar
John
16" Wheels
Wonderbar
John
There was a Z28 and an IROC-Z. There is no such thing as an IROC-Z28. All IROC-Zs are Z28s. The Z in IROC-Z stands for International Race Of Champions - Z28. If your car has 15" rims, then you have a Z28, not an IROC-Z. From 1985 - 1987, to get an IROC-Z, you ordered a Z28 with the B4Z option code. Without the code, you get a Z28, but with the code, you get the IROC-Z. In 1988, that changed. All you needed from 88-90 was the Z28 code because all Z28s were IROC-Zs. GM just reduced the model line to 2 cars, the Sport coupe or IROC-Z.
The rear taillights on the Z28 are also grid style starting in 1985.
The wonderbar is a front end stabilizer that on the front of the car. Do a search and you'll find pictures of one installed and where it connects. It was available ONLY on the IROC-Z.
Car: 87 Camaro Z28
Engine: 355
So have 15' wheels and no iroc rpo code so i cant be an iroc. Yet this chart still confuses me. I highlighted the two models that have my drivetrain. I didn't highlight the LT because i have all the z28 trim and louvers so it cant be that. That leaves the iroc and the "iroc-z28". The plain z28's dont come with carbs and it says they were all tpi. So if there was a such a thing I guess i have an "iroc-28"?
forgot to mention it is also an auto
1987 Chevrolet Camaro Drivetrain List
Yr
Model
Trans
Engine
code/type
CR
Displ.
HP
Torque
Induc-
tion
Manual
std.
Manual
opt.
(G92)
Auto
std.
Auto
opt.
(G92)
87
Sport Coupe
LT
RS*
M5,A4
LB8 V6
8.9:1
2.8 (173)
135@4900
160@3900
MFI
3.42
3.42
87
LT
A4
LG4 V8
9.3:1
5.0 (305)
165@4400
245@2800
4bbl
2.73
87
IROC-Z
Z28
M5,A4
LG4 V8
9.3:1
5.0 (305)
170@4400
250@2800
4bbl
3.23
2.73
87
Z28
A4
LB9 V8
9.3:1
5.0 (305)
190@4000
295@3200
87
Z28
M5
LB9 V8
9.3:1
5.0 (305)
215@4400
295@3200
87
IROC-Z
A4
LB9 V8
9.3:1
5.0 (305)
190@4000
295@3200
3.23
87
IROC-Z
M5,A4
LG4 V8
9.3:1
5.0 (305)
170@4400
250@2800
4bbl
3.23
2.73
87
IROC-Z
M5
LB9 V8
9.3:1
5.0 (305)
215@4400
295@3200
3.45*
87
IROC-Z
A4
L98 V8
9.3:1
5.7 (350)
225@4400
330@2800
3.27*
*Borg-Warner rear axle *RS available in only California
Yr
Model
Trans
Engine
code/type
CR
Displ.
HP
Torque
Induc-
tion
Manual
std.
Manual
opt.
(G92)
Auto
std.
Auto
opt.
(G92)
87
Sport Coupe
LT
RS*
M5,A4
LB8 V6
8.9:1
2.8 (173)
135@4900
160@3900
MFI
3.42
3.42
87
LT
A4
LG4 V8
9.3:1
5.0 (305)
165@4400
245@2800
4bbl
2.73
87
IROC-Z
Z28
M5,A4
LG4 V8
9.3:1
5.0 (305)
170@4400
250@2800
4bbl
3.23
2.73
87
Z28
A4
LB9 V8
9.3:1
5.0 (305)
190@4000
295@3200
87
Z28
M5
LB9 V8
9.3:1
5.0 (305)
215@4400
295@3200
87
IROC-Z
A4
LB9 V8
9.3:1
5.0 (305)
190@4000
295@3200
3.23
87
IROC-Z
M5,A4
LG4 V8
9.3:1
5.0 (305)
170@4400
250@2800
4bbl
3.23
2.73
87
IROC-Z
M5
LB9 V8
9.3:1
5.0 (305)
215@4400
295@3200
3.45*
87
IROC-Z
A4
L98 V8
9.3:1
5.7 (350)
225@4400
330@2800
3.27*
The Z28 base engine was the LG4 (4bbl) Tech section needs some work.
John
Your highlighting didn't come thru. There is no IROC-Z28 model. There is just an IROC-Z or a Z28 as I mentioned before. The tech article doesn't state there is either. Where are you getting this? The tech article refers to 2 models in the LG4 square. The IROC-Z and the Z28. The first box isn't referring to one car as the Sport Coupe LT RS. It's referring to 3 cars and each model is on it's own line. The same with the IROC-Z/Z28 box. There is redundancy in the stats as it has just IROC-Z again further down with the LG4.
You have an LG4 (carbed) Z28. That's it.
edit: I do see that at the very bottom the tech article refers to the quantity of IROC-Z28 as 38,889. That is because the IROC-Z is an IROC-Z28 but it's always referred to as the IROC-Z
Car: 87 Camaro Z28
Engine: 355
87
IROC-Z
Z28
M5,A4
LG4 V8
9.3:1
5.0 (305)
170@4400
250@2800
4bbl
3.23
2.73
That was in post directly from the chart in the 87 camaro data page a few days ago. I do beleive what you say that it is an z28 with no connection to the iroc. Just wanted to point out that it was written on this site. And what someone said before that a z28 base model could come with a carb now makes sense. The chart must not show all the options.
Some one seem to have up dated the chart on that page as now the "Iroc-Z28" was removed and it now just says Z28.
So maybe my curiosity did some good in unintentionally
catching a mistake.
Thanks for all who helped.
87
IROC-Z
Z28
M5,A4
LG4 V8
9.3:1
5.0 (305)
170@4400
250@2800
4bbl
3.23
2.73
catching a mistake.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I think it's pretty much assumed that IROC + Z28 = IROC-Z28. If it didn't, then why would they have the Z on the end? It would simply be IROC if the abbreviated Z28 wasn't on the end of it.
Even GM calls it an IROC-Z28
Car: 87 Camaro Z28
Engine: 355
Cool now i know im not going crazy and that it does exists. Although im pretty sure mine is a base model Z28. Thanks Reid
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Axle/Gears: 3:27 Borg Warner
In 85, GM press called the new TPI mill the 305 HO, while the factory continued making the 305 carb High Output mill.
2 HO motors? No...the right hand did not know what the left one was doing.
The beat goes on.
The beat goes on.
The lb9 was often called the HO even later on in dealer literature...
On the one hand the car never had the badge of "HO" like the L69, but it was higher output than the LG4 or the LO3 so technically it is not incorrect to call it an HO. So often people are trying to call the LO3 & LG4 the HO engine when trying to sell a car...
John
John
There are a lot of inconsistancies with the product literature and the actual product. If you read the above page from the 1985 brochure, they are not calling the car an IROC-Z28. They are referring to the car as the International Race Of Champions Z28 or IROC-Z.
This is actually a very petty argument that you're pushing. There is no such car as an IROC-Z28, only the IROC-Z or a Z28. The above article even states that financing your new IROC-Z is as easy as GMAC. They are using the acronyms for International Race of Champions as IROC when referring to the new model of Z28.
GM documentation has been known to be wrong before as they constantly refer to the 350 as the B2L in alot of written material. All Chevrolet engines have an "L" designation for the engine itself. The B2L was a package of required items when ordering the L98. My window sticker even mentions the 350 as B2L, but it's actually an L98.
Car: A few camaros
Engine: V6, 305 TBI, 350 TPI
Axle/Gears: 2.77
Yeah man looks like you have a Z28 not an IROC-Z28. The difference that I can tell between Z28's and IROC-Z28's are the suspension and decals. So to make things easier to understand, IROC-Z's are Z28's they just have a beefier suspension and decals.
Administrator
catching a mistake.
catching a mistake.
The 85 305 TPI was a more powerful engine than the 305 H.O. with brand new EFI technology, I really think that's all they meant when calling it H.O., but it never got the actual name from GM. That would have been confusing.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
1989 IROC-Z
The later IROC-Z after the B4Z RPO (to get an IROC-Z Z28) was dropped in '88 and all Z28's were IROC-Z's (88-90) . . .
Just thought I'd throw in my to help confuse things!
I think the question has been answered to what the poster has. Anything beyond that may go off topic. If we need a new thread, then we can start another.
