5.0 liter h.o. dyno numbers
Car: 1985 IROC-Z
Engine: l69
Transmission: m5
Idk if I'm posting in the right section, if not I'm sorry. I wanted to kno if anybody here dynoed a stock 5.0 liter h.o.? If so what were the numbers
Re: 5.0 liter h.o. dyno numbers
I dynoed mine 2004 or 2005 I don't remember for sure. But I think it is a bit of a freak. It put down between 168 and 171 horsepower and 210 to 215 torque over four pulls. Which would put it about 205-210 at the flywheel. I used to take it to the track in the early 90's it would run 14.7-14.9's at about 94mph. The only thing that was done to it at the time was the convertor went bad so I took it off and beat all the stuff out of the inside. It was rattling pretty bad. Other than that it was 100% original. I could not afford to do anything to the car back then. I always thought people underestimated the L69. Back in the day my car would run door to door with a friend's 92 LB9 auto.
Car: '84 Z28
Engine: L69
I've always wondered about this too. I hear these engines were underrated in the hp dept. I'd love to see a low mileage stock L69 car on a dyno and see just what kind of numbers it produces.
Car: 2001 Trans Am WS6
If you used a Dyno Jet then those numbers are actually right on track. I know a lot of people like to quote a 15% loss but that is not correct using a factory power rating. The factory ratings are more conservative than aftermarket ratings. When using factory flywheel ratings, a Dyno Jet shows about an 11% loss to the wheels. 190hp*.11=169hp.
If I remember correctly, GM said that the car would be rated at 200hp with 91 octane which equates to around 178hp at the wheels.
I have compared a LOT of different cars and the 11% rule is very accurate.
Car: 92 Trans Am 1LE JY
Engine: 305/5.0
Transmission: 5spd
Numbers were:
223 HP
290 TQ
The dyno we used was a Mustang dyno. Most Dyno Jets I have seen are pretty optimistic with thier readings. Hopefully soon I will get to retest it on a new Superflow Autodyn 30. We'll see how that goes. It's still stock, just more miles. Maybe it's loosened up and will make more power.
Engine: 4++,350 & 305 CIs
Let me know either way!
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
My '84 Trans Am with the L69 and auto transmission got these results at 101K miles with 87 octane gas:
170.1 RWHP @4217 RPM
232 FT.LB. @3390 RPM
Only mod was a Flowmaster catback.
Springster
Sep 13, 2015 01:38 PM
Doobie52
Sep 11, 2015 06:19 PM
