VIN DECODING
Old Aug 27, 2011 | 01:29 PM
usedcarl's Avatar
VIN DECODING
Is there a site to go to where I can put my vin number in and have it decoded, I wanna know rear gear ratio, engine number etc...I just found that this car I bought was is a first year IROCZ, so before it gets all hacked up, I wanna research it first. please help,
Old Aug 27, 2011 | 02:52 PM
GShipp85Trans's Avatar
Car: 1985 Pontiac Firebird TransAm
Re: VIN DECODING
http://www.compnine.com/vid.php
this will tell you almost everything you want
Old Aug 27, 2011 | 05:38 PM
usedcarl's Avatar
Re: VIN DECODING
ahhh thanks, but it says this vin # isnt in their data base.
Old Aug 27, 2011 | 05:45 PM
Re: VIN DECODING
yea i had that with one of my car's i guess it was worth a try though im not sure of another site that decode's it
Old Aug 27, 2011 | 05:52 PM
usedcarl's Avatar
Re: VIN DECODING
thanks anyways
ANYONE ELSE?
Old Aug 27, 2011 | 06:25 PM
JT's Avatar
JT
Community Administrator
Re: VIN DECODING
Unless the car is Canadian, Compnine won't show information for a ThirdGen that is older than 1990 as they don't have complete records.
Best option is to look for the SPID on the center console. It will contain the RPO codes specific for that vehicle. If it's not there, you can either purchase an invoice from GM or try to locate the buildsheet (if it does have one - it may not).
Old Aug 28, 2011 | 05:34 AM
fltche1's Avatar
Car: 1986 Trans Am
Re: VIN DECODING
You made mention of buying the invoice from GM.... Would that give you all the RPO codes for the car? Would it basically be a copy of the factory buildsheet? And did not all cars come with a factory build sheet and where would you find them on an 86 trans am? I am sure that there are a lot of who would like to know more about our cars.
Old Aug 28, 2011 | 06:06 AM
JT's Avatar
JT
Re: VIN DECODING
For your 1986 Trans AM, you would go through PHS to get an invoice (not a buildsheet)
http://www.phs-online.com/
The invoice will contain some of the RPO codes, pricing for the options, ordering/receiving dealership information, lock numbers and a misc or two other things. Do you have your SPID located inside the center console? It will contain all RPO codes for that vehicle.
My experience has been getting an invoice does not include every single RPO option. It also is not a replacement for a buildsheet. The buildsheet has a lot of data that is unique to the vehicle and there is no known replacements. Not all vehicles received the buildsheet as the assembly line workers would often trash the documents (there was more than one). If the document was placed inside the car, it could have been removed by the dealership or previous owner. If it's actually in the car, it could be found just about anywhere if it is in the vehicle at all (under the carpet, behind the dash, up in the bumper cover, etc., are spots that some have found their buildsheet).
Old Aug 28, 2011 | 08:38 AM
fltche1's Avatar
Car: 1986 Trans Am
Re: VIN DECODING
I am not sure what you mean... Do you mean inside to center console box or the main structure of the center console? I looked inside the box and there was nothing.
Old Aug 28, 2011 | 05:40 PM
JT's Avatar
JT
Re: VIN DECODING
Open the center console lid. On the inside wall of the center console, you should see a black and white RPO sticker with several 3-character codes. You may have to remove the cassette holder (if equipped) to see it.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Elephantismo
Feb 13, 2019 12:51 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
AussieZ28
Sep 30, 2015 03:36 PM
F-body-fan
Sep 24, 2015 08:29 AM
