Interesting option combo on this 91 TA
Old Mar 31, 2016 | 08:47 PM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
This car has most options (t-tops, power windows, etc) with an LB9 TPI motor + 700R4, but has no AC:
http://www.hemmings.com/classifieds/...d/1815128.html
I didn't realize you could get a TPI car that late in the game with no AC, not being a 1LE...
Old Mar 31, 2016 | 10:11 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Re: Interesting option combo on this 91 TA
Well with it being Canadian built Im not surprised you could order one without A/C.
Old Mar 31, 2016 | 11:20 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It was built at the Van Nuys, CA plant.
I believe the combination of both no A/C and the performance axle ratio was required to trigger the 1LE goodies.
Old Apr 1, 2016 | 05:40 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
With Pontiac, (atleast by 91ish) you could just order 1LE and it would add the needed supporting items.
Made it easier to do than the chevys cryptic ordering system.
Old Apr 1, 2016 | 07:50 AM
Engine: 5.7 LS1
Hmm weird, I didn't check the build date, I just checked out the cluster and assumed it was Canadian since it was in kilometers.
Old Apr 1, 2016 | 09:31 AM
JT's Avatar
JT
Community Administrator
While this Trans Am was built for the Canada area, all ThirdGens from 1988-1992 were built at Van Nuys, CA. The cars are simply exported/shipped.
Old Apr 1, 2016 | 03:56 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Always loved a black TA with charcoal crosslace wheels...but I don't think I could touch one without A/C.
I wouldn't have when I lived in MA...and I especially won't living in FL now I was using A/C in my SS in December this past year!
Old Apr 6, 2016 | 01:32 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
NEat car, I think the reason why it is not a 1LE is it is a LB9/Auto/Z49 (Canadian).
1G2FW23F9ML244758
Vehicle: FIREBIRD 2 DR
Year: 1991
Build Date: 1991-05-02
Found 47,612 vehicles matching that year and model in our database.
RPO Description Matches
1SB PACKAGE-OPTION 02 (1SB) 19,280
18P WHEEL COLOR,CHARCOAL METALLIC (18P) 37,994
19Q MOLDING COLOR,BLACK (19Q) 7,831
41U EXTERIOR COLOR,PRIMARY,BLACK (41U) 7,965
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW) 7,587
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW) 7,587
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 11,102
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 31,438
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 31,861
829 SEAT BELT COLOR - MED DK GRAY (829) 31,861
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 11,102
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 13,751
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 47,612
AN4 RESTRAINT PROVISIONS,CHILD(CANADIAN) CHILD RST PROVISIONS(AN4)(CANADIAN) 1,498
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 44,743
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 41,671
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 41,671
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 28,389
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 41,671
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84) 46,790
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1) 27,277
C41 HEATER,OUTSIDE AIR,WITH FAN AND DEFROSTER HTR(C41) 666
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 33,076
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 46,761
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4) 27,277
DG7 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7) 27,108
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42) 25,346
D7C GEAR-SPEEDO DRIVEN (25513045) (D7C) 5,358
D8N SENSOR VEH SPD (10456088) (D8N) 31,204
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 13,733
E5Z ADAPTER - SPEEDO - DELETE 47,612
E9Z KEY - SPEEDO - DELETE 47,612
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2) 10,360
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2) 16,938
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 9,171
IPC TRIM,INTERIOR DESIGN (IPC) 44,743
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41) 41,181
K05 HEATER,ENGINE BLOCK(CANADIAN) ENG BLK HTR(K05)(CANADIAN) 1,498
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 30,237
K68 GENERATOR,105 AMPERE 105 AMP(K68) 8,835
LB9 ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9) 5,346
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 43,399
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0) 43,399
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 43,196
NP5 STEERING WHEEL,SPORT,3-SPOKE,LEATHER WRAPPED(USED WITH PERFORMANCE PACKAGE Y56,SPORT PACKAGE WN2) LEATHER WRAPPED STRG WHL(NP5) 6,182
N65 WHEEL AND TIRE,SPACE SAVER SPARE(STEEL) STOWAWAY SPARE(STEEL)(N65) 2,566
PW7 WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7) 6,264
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC) 10,360
R6Z CONTROL - SALES ITEM NO. 25 41 Would like to know what this is
R7G CONTROL - SALES ITEM NO. 32 556
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61) 1,498
T93 LAMP,TAIL AND STOP(SPECIAL)(DELETES CHROME EDGING)(USED WITH INTERNATIONAL WJ9) SPECIAL TAIL & S/LP(T93) 5,059
T96 LAMP,FRONT FOG(USED WITH APPEARANCE PACKAGE WS4) FRT FOG LP(T96) 33,888
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3) 47,612
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 17,942
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 47,612
U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR KPH SPEEDO(U19) 3,724
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 47,612
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 47,612
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 37,477
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 44,388
WS4 TRANS AM(MERCHANDISING OPTION)(2FS87 + WS4 = 2FW87) TRANS AM(WS4) 6,182
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6) 10,360
Y83 TRANS AM PACKAGE(MERCHANDISING OPTION) TRANS AM(Y83) 3,313
Z31 IDENTIFICATION - PRICE SHEET ADVANCE 1,497
Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49) 1,498
BarryV8
Jul 2, 2025 07:48 AM
utfan01ss
Mar 13, 2016 01:06 PM
1988_f-bird
Mar 7, 2016 12:35 AM
B4C5.7
Mar 2, 2016 08:33 PM
gt4373
Mar 1, 2016 11:10 PM
