88 GTA K-member factory finish
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
Hey guys,
I was wondering if anyone had any information on what the factory finish should be on the K member of a 88 GTA. I plan on rebuilding and detailing the undercarriage of my car this winter and would like to make everything as correct as possible. I have searched through the "reference car" thread and seem to see some that are bare metal, some that are black, and some that look bare metal with black towards the ends. Unfortunately in my teenage years I had painted the K member black on my car, so I can't really play detective to figure out what finish my k member originally had. Any help if much appreciated.
Car: 90 Formula / T-tops
Transmission: MD8
Re: 88 GTA K-member factory finish
pretty sure my 90 was black, I can still see some paint on it, i'll probably have it in the air in the next week or so, and can take a closer look.
I'm also doing this as I go thru things. Check our this thread, do you see this color anywhere?
https://www.thirdgen.org/forums/hist...-spindles.html
Engine: 4++,350 & 305 CIs
Detail away !!! 2 different cars in these pictures
Transmission: MD8
Funny, I had saved that top photo too. My Maui caught more paint on the radiator housing than his. Were these painted by people or machines?
Another point, I think my passenger side k-member near ball joint is orange. never noticed anything on driver, will have a closer look at both.
my sway bar mounts were definitely black from factory. what is that paint doing on the bump stop thing.
I'm not sure how the cars were painted, LenardS would probably have some good info about that.
If you get a chance to see the pass A-arm I'd like to know what color they used
I've never seen anything other than bare front sway bar mounts and painted rear mounts. GMs really really weird sometimes.
That's the only car I've seen with paint on the snubber. Often wondered if it was some kind of mold release compound that stayed on it randomly??
Engine: 305tpi
Thank you for all of the information and pictures. Also, for anyone else who is also looking for more reference pictures, I came across this thread.
https://www.thirdgen.org/forums/hist...ge-photos.html
Received 1,161 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Must depend on the year. Here's my old 82 Z28, 22k miles. An absolute TON of bare metal parts. This car was stored in a climate controlled garage its entire life and nothing was rusty at all. For whatever reason, the rear sway bar bushings even survived and were still just fine
Transmission: MD8
finally got her in air. k member black, ends near ball joints orange, both sides, i got moon problem solvers in there, both sides, don’t recall replacing those, have to look in my records. was wondering if i ran over some orange paint until saw both sides. pardon my grease, trying to get her lubed up after 25 years
