Speedometer question...
Old Aug 2, 2020 | 08:02 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I found this car for sale on Ebay. It's kind of a twin to my car, but a year newer, and no G92. It has 15k original miles. But it has a 115 mph speedometer. Has 16" wheels, too
1989 IROC-Z convertible, 305 TPI, 5 speed, 3.08 gears, no 4 wheel disc brakes. Has the speedometer been changed??
https://www.ebay.com/itm/324248450531
Old Aug 2, 2020 | 08:09 PM
dagwood's Avatar
Top Answer: 1
Re: Speedometer question...
Or, is this a 15" wheel car that someone upgraded to the 16" wheels???
Or is it just legit?? I've just never seen a TPI, 16" wheel IROC-Z with a 115mph speedometer before.
Old Aug 3, 2020 | 01:28 AM
JT's Avatar
JT
Community Administrator
I'm not a Camaro guy but the RPO code QLC tells that it's a 16" rim/tire. So there's that.
The speedo is not RPO code specified, to my understanding, so I can't help with that.
Old Aug 3, 2020 | 12:49 PM
dagwood's Avatar
Top Answer: 1
Thanks man! Yeah, I just don't think that speedometer is right for that car. Hopefully someone can shed some light on this
Old Aug 3, 2020 | 04:40 PM
Abubaca's Avatar
Not to split hairs, but I think the16x8 WHEELS are N96, and the 245/50/16 TIRES are QLC. I know because I was actually JUST looking it up earlier!
Old Aug 3, 2020 | 04:41 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
I think the speedo is correct. Only the L98s came with the 140mph speedos.
Old Aug 3, 2020 | 04:52 PM
JT's Avatar
JT
No problem and you're correct there are two options - the tire and the wheel. I stated what I did as, normally, 16" tire goes on a 16" rim
Old Aug 3, 2020 | 06:42 PM
dagwood's Avatar
Top Answer: 1
Nope, they both did. Usually the 115mph speedometer is found in either RS cars, or any Z28 or IROC-Z that didn't come with speed rated tires (why I was asking about the wheels, the 15" wheels did not have high speed rated tires)
My 89 RS TBI 305 has a 115 mph speedometer
My 88 IROC-Z LB9 TPI has the 145mph speedometer
Old Aug 3, 2020 | 07:08 PM
JT's Avatar
JT
I believe the gears is part of the equation. Your 1988 has the performance axle while this car does not. Atleast on the Firebird side, that's some factor along with the redline tachometer. Had this been a Firebird, I would expect the 120mph speedo so I would think this car is correct. But I'm not on the Camaro side!
Old Aug 3, 2020 | 08:07 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Mo g92, no 145 speedo. U see these in the vert 305 tpi camaros.
Old Aug 3, 2020 | 09:23 PM
dagwood's Avatar
Top Answer: 1
Ok that makes sense. I wasn't really a convertible guy until lately so I guess I never noticed that
micktroup
May 6, 2019 11:35 PM
VJimmy
Jul 15, 2011 02:39 PM
RPOL98
Apr 19, 2007 12:47 AM
yzarcem
Jun 4, 2004 09:13 AM
