cyberdyne digital gauge cluster for 85-89 camaro f/s
I have a digital cluster for sale I have installed it and it works great. but I think I am going to change the route i'm going and do the auto meter gauges instead.. It is ready to install. only bad thing is the blacked out lens is broke and it could be glued together or tint the factory lens in yours ad it will fit to this is what I was going to do.. also the trip and odometer unit was hacked when I got it I wasn't worried about it, but it can be swapped out easily. i'm looking for 120 shipped
1 Post
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
Re: cyberdyne digital gauge cluster for 85-89 camaro f/s
Does this have its own sending units or does it workoff the factory ones?
this works off the factory units it is already to go soldered in. all you have to do is hook up the speedo wire. I had it hooked to the ez-tcu since I am running a 4l60e.
Car: 1985 Black z28 T-top, 09 eclipse
Engine: Carb'd 305 soon to be a 400 sc
Transmission: 700r4 to T5 swap
any pics of the back?
i can take some, it is in my car now. are you wanting a pic of the back of the factory unit it installs in or the cyberdyne piece?
Engine: gone
Transmission: gone
Axle/Gears: gone
so you have to run an electronic speedo with this?
I know you can use a hall effect unit to send a signal to it but as long as you have you cable driving the optical sensor then you should be able to tap into it and use that . not totally sure but I found these facts while searching the site.
again I am using the ez-tcu with my tpi so it has a wire for this purpose which it whaat I am using right now.. I am going to swap over to all autometer gauges for a ls swap soon so I wont be needing it . the tcu has a built in speedo with the handheld so I can use it for the time being . figured I would give some one a chance to get a digital dash.
Engine: gone
Transmission: gone
Axle/Gears: gone
have another question when you say the trip and odometer were hacked? you mean this unit will not be able to keep track of trip and/or miles?
well when you install this into a factory cluster you have to remove the speedometer front faceplate. but the odometer internals are left.. so you still have the use of the optical sensor to send a sig to the ecm and drive the odometer and trip as well. when I got it someone apparently didn't do it right and the trip was messed up. I have a spare speedo and trip i will throw in as well so someone can fix it as it should be..
