82-92 CAMARO and FIREBIRD TURN SIGNAL SWITCH WIRES PROTECTOR (SLEEVE)
Car: 1987 Trans AM WS6
Transmission: TH700R4 Stock
Axle/Gears: 3.08 LSD
Hello guys,
I'm looking for a steering column turn signal switch wires' protector ( GUIDE/SLEEVE ), the BLACK PLASTIC PIECE that mounts above the steering column bracket. This part is for a 87 Firebird. It should be the same for ALL 82-92 Camaros and Firebirds.
THANK EVERYONE FOR YOUR INTEREST, PATIENCE AND KINDNESS
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 82-92 CAMARO and FIREBIRD STEERING COLUMN TURN SIGNAL SWITCH WIRES' PROTECTOR(SLE
Here it is a link of how it looks like : http://www.steeringcolumnservices.co...-protector.php
THANK YOU AGAIN FOR YOUR INTEREST, PATIENCE AND KINDNESS
Its purpose is to protect the turn signal switch wires that run under the steering column.
Engine: 5.0 EFI
I see.I might just have one,let you know tomorrow,I have to check.
Hello mantaguy,
Did you find the part?
Engine: 5.0 EFI
Found it!!!
Mine only has 2 mounting holes,this is Off my 86 TA,make me an offer I can't refuse.
Hello Mantaguy, I have just sent You an e-mail message !!!!!!!!!!!!
Hello Mantaguy,
Did You read my other PMs ?
There are other parts I'm looking for
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
Hello guys,
Car: Camaro
Re: 82-92 CAMARO and FIREBIRD TURN SIGNAL SWITCH WIRES PROTECTOR (SLEEVE)
Hello guys,
https://www.facebook.com/ThisWeekInCamaro
443-527-9573
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 11, 2015 10:11 PM
