[NJ] Power Seat Recliner
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Power Seat Recliner
No longer needed Thanks.
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Power Seat Recliner
Not sure if you want to travel a little but Blacey's u pull auto in wrightstown has 2 power seat cars in their yard right now. I was just there a few days ago and both seats were completely intact.
Engine: 5.0 EFI
Where at in Wrightstown??Hey thanks Eric,I just Googled it,not to far,about an hour.Are the seats any good??,if so,they might not break up the seat.
What Years and make??
Engine: 305, 355
One car is an 85 z28 with gray custom cloth and the other is an 88 sports coupe with tan custom cloth. I doubt they would give you a hard time as the seats are pretty worn out and exposed to the elements. Ill give you the heads up that they are kind of on the expensive side as far as u pull it prices go for some things but their a great group of people down there. also there is an 84 TA if there are any other parts your looking for.
Engine: 5.0 EFI
The 85 would be perfect,that part I'm looking for is 85-86 only,thanks a lot Eric,I'll give them a call in the morning.
Car: 89 Iroc Convertible
Fran...Blaceys is on rt 537 not too far from great adventure and they are on the more expensive side price wise
I checked, the part numbers are: (L) 9203 and (R) 9202.
Looking closer at your diagram the part labeled "3" is actually just the passenger side seat recliner (shown from it's backside), I have that too if you're interested.
These were pulled off my '83 with the 6-way power driver's seat. I've attached pics of the driver-side and passenger-side.
Engine: 5.0 EFI
Thanks Red,but apparently they are the same ones I have now(7 with paddle 6,if you look at no.3 it has the paddle no.22,that's the one I need to use the panel no.17 & 8. for power seats.I really appreciate you doing this for me.Thank You.
Because paddle no. 22 is only on the passenger side recliner so if you're looking for that for a driver's side seat then it doesn't exist, to my knowledge. If you look at no. 3 it's just the passenger side recliner shown from it's backside, and doesn't get attached with panel 17 as that is the driver side panel.
My car had panel 17 and 8 on the factory driver's seat, but maybe they were different in '83 or something? but it doesn't look different to me, idk.
Engine: 5.0 EFI
Holy crap,I thought the P was for power so your saying I don't have to change?but I can't get these panels to fit.
Yup, those panels should fit just fine as long as you've swapped out the complete power seat track and everything.
Are both of those panels there that hold the switchgear the same? the one in the top left looks shorter than the other.
How exactly are they not fitting? is a bolt not lining up or is it a space issue or what?
Engine: 5.0 EFI
Yes those two panels are the same,I'm having a problem mounting the switch panel and the hinge panel 17 & 8.
Engine: 5.0 EFI
Nothings lining up there is no hole to mount the black fastener on the seat frame.
As for the switch panel, the holes should be predrilled, and it's a tight fit (as it took a fair amount of wiggling to get it off once it was unbolted on mine). I recommend raising the seat as high as it can go, it may help.
Engine: 5.0 EFI
Your panels on the drivers seat are the same ones I'm trying to mount.Where does the black fastener(in my pic) mount to the power seat frame? I really appreciate you taking the time to help me.
Engine: 5.0 EFI
I'm wondering if it would be easier to attach everything with the seat out.
does that all make sense? and glad to help!!
Engine: 5.0 EFI
I Think I have the seat frame in backwards,because those mounting plates are towards the rear,is this mounted right?
Is that pic how it is now or after you turned it around? Because on mine the elongated holes on the top mount to the front of the seat bottom, and by your picture it appears you have them mounting to the back.
I'm surprised at the difference in appearance from the '83 to yours, looks like they made the whole apparatus a little simpler, haha.
Engine: 5.0 EFI
So these mounting things should be towards the front?
Engine: 5.0 EFI
You know, I'm a big advocate for Patience,take your time and do things right the 1st time,I screwed that up.I'm going to take the whole thing out and start over with it.
Thanks a million for your help Red
1992 Trans Am
05-10-2023 07:19 PM
sailtexas186548
08-24-2015 10:11 PM
