Re-covering dash pad.. leather or vinyl?
Old Jun 6, 2006 | 03:18 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Im going to have my dashpad recovered (picked up a good one from canada, want to cover it before it starts to eat itself), who has done this and how did it hold when using either leather or vinyl? Any pice ? It seems obvious that I would want leather, but I live in a town that has 308 days of sunshine a year on average, and hit 100 before June... i'd like to never have to look at this dash again basically. I don't know how the weather will hold up here.
Any suggestions. ?
Old Jun 6, 2006 | 04:34 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I feel ya about the heat. DFW isn't as hot, but I'm reluctant to replace my dash pad with and OEM/OER pad. I'm going to see if I could fiberglass it and paint it. Both vinyl and leather will be dried up in the sun, but if I had to choose one, I would probably go with vinyl.
Old Jun 6, 2006 | 04:39 PM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
hmmm, well you can always go cheap and put on a carpeted cover type deal from sears. hahaha, ill give you mine. it rains here about 308 days of the year.
Old Jun 6, 2006 | 09:18 PM
Car: 1987 IROC Z
Appreciate the offer.. but im wanting a nice dash, something.. anything better than the project sitting out on my balcony.
- note, if your dash is bad enough to throw away, light it on fire, and let it burn. You will find that their is a pretty steady skeletal structure under all the padding made out of metal. its just begging for someone with injinuity could rebuild the dash... make the better dash.
Anyway.. I think I am going with the Pleather/ vinyl stuff.
Old Jun 7, 2006 | 09:27 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It depends on what you're trying to accomplish.
If you use leather, since it doesn't stretch, rather than "wrap" the piece, you'll need to have an upholstery shop stitch it into shape, which will give a nice european look.
If you want a stock appearance, then get some 3-way stretch vinyl, a heat gun, and good spray adhesive and go to town on it. If you're good with the vinyl, you'll be able to stretch it all the way around.
In both cases, you'll have a nightmare handling the speaker openings if you've got a Camaro, so I'd suggest filling those and relocating your front speakers. If you've got a firebird, those grill openings can be easily dealth with.
Old Jun 7, 2006 | 12:33 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I bought a carpet dash cover from Classic Industries. I leave it on when I'm drivin around and just take it off for shows/ special occasions. It just sits on the dash (you don't need the velcro) so it's easy to take off.
Old Jun 7, 2006 | 12:59 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'd like to see it wrapped and stitched in leather. Or an alcantra type material. I've been wanting to try that on a 4thgen dash but haven't gotten around to it.
Old Jun 7, 2006 | 01:14 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i would love to know what will hold up best to the sun and looks good. we get a few less sunny days, but not much (also in the 100's).
Old Jun 7, 2006 | 07:47 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Is there a way you could modifiy a Camaro dash to use the firebird grills? I've never had a chance to get a close look at a firebird so I really don't know how they attach.
Old Jun 7, 2006 | 08:31 PM
purpleZ-28's Avatar
so i dont really understand why a camaro dash is harder to recover. the firebird dashes look harder, in my expierience that is.
and as far as the dash, i have an old carpet pad that goes on top of it. it was on it when i bought, and i took it off the day it came home!
if anyone wants it, its free.
Old Jun 8, 2006 | 07:21 AM
Jim85IROC's Avatar
It's pretty obvious if you just look at the dashpad. For the firebird, you can unscrew the speaker grills, wrap the pad, then reinstall the grills for a great look. On the camaro there aren't speaker grills, just slots in the dash pad itself. Getting the vinyl down inside of those slots, and getting it to stay there without looking like a hack will be very difficult.
Old Jun 8, 2006 | 12:06 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Are the only differences the speaker grilles and heater vents? Would it be possible to use a bird dash and then notch the frontside center where the vents stick out since it'd be covered in fabric anyways?
Old Jun 8, 2006 | 12:25 PM
Jim85IROC's Avatar
The depth is different. The camaro dash pad is an inch or two deeper than the firebird pad.
Old Jun 8, 2006 | 03:35 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
I just took the carpet mat off, to clean. My once pristine dash pad cracked. I'm so bummed. Damn Arizona sun.
Old Jun 8, 2006 | 07:22 PM
purpleZ-28's Avatar
OH! ok, now i know what your talking about. that would make it harder wouldnt it?
Old Jun 17, 2006 | 04:12 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
i have a big crack in my dash, sould i fill the crack with epoxy and just cover over the existing pad or would that look like ****? also would that stablize the crack?
Old Jul 30, 2006 | 11:34 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ttt i want to know the answer too, iknow there is some kind of vinyl epoxy out there that would work great
someone out there knows
also where do you find 3 way stretch vinyl material ?
all we have here is wal mart lol
thanks
Old Jul 31, 2006 | 04:17 AM
purpleZ-28's Avatar
depending on how large it is, you may want to replace it. you could fill it and cover it, but that just depends on your taste, if you like stock, or if you like it alittle more custom i guess.
Old Aug 2, 2006 | 01:08 AM
Mattwolfy's Avatar
I've been kicking around the idea of doing the fiberglass covering, the problem that i keep coming up with is it rattling, because on a crappy dash im worried about the fiberglass separating from the dash itself.
I even thought about epoxy on the cracks and using a bed liner coating on it. I would think to get around the whole speaker thing with the vinyl that you could just cover them up with the vinyl and use like a hot awl or screwdriver to make holes, but not too hot or it will burn through wierd. Then I think, eventually ill come across one at the junk yards here worth replacing. but it would look cool to redo one with the carbon fiber vinyl ive seen on ebay.
Matt
Old Aug 2, 2006 | 04:46 AM
purpleZ-28's Avatar
bed liners are... well, abraisive, for lack of better term. theyre very ruff, and just covering that wont make it look any good.
Old Aug 2, 2006 | 06:44 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
it is not rough if you put it on smooth. My interior is "bedlined" and its smooth because I didnt use the textured roller. It is all about how you work it..
Old Aug 2, 2006 | 06:06 PM
purpleZ-28's Avatar
i actually srayed mine on my 71 GMC. its pretty rough. I wouldnt know about other ways to put it on smooth, because I rolled it first, and it was rough, and then sprayed it, and it came out rough also, so thats my expierience.
Old Aug 2, 2006 | 09:20 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
use a 4" wide soft bristle brush. smooth as glass.
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Feb 25, 2016 09:02 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
tattmann
Sep 27, 2015 05:20 PM
indygene
Sep 26, 2015 11:21 AM
