82 83 84 bird pad vs 85-up ones
Old Jul 30, 2006 | 11:45 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
really whats the differences between 82 83 84 bird dash pads and the 85 up ones
is there any way to get an 85-up one to work on an 82 83 84 without major parts swapping
got pics?
thanks
Old Jul 30, 2006 | 02:22 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Transmission: Manual
The difference is cosmetic, they will bolt right in, I had an 87 dash pad in my 83 for a while.
The 82-84 have two lines molded into the front for looks, the later ones are smooth.
Old Jul 30, 2006 | 09:53 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
I should also point out that the earlier of the two with the lines molded in are much harder to find in good condition.
Old Jul 30, 2006 | 10:45 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
as far as fitting the dash pads are the same, i put an 88 dash pad in an 82, then an 85, without any problems
Old Aug 3, 2006 | 12:00 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
right
but anyone knows that much :P
ive only ever come across one, in an 84 s/e i cut up
i shoulda kep the pad instead of sellin it,
it was mint, as was the entire interior of the car, absolutely was in brand new factory pristine condition
gone
hum
crazy
such is life
thanks
appreciated
thanks
Old Aug 3, 2006 | 03:35 PM
MNformula350's Avatar
that is why I am hanging onto one I have that is P E R F E C T, In case I need to replace the one on the Formula at a later date.
And like has already been stated, they will all interchange perfectly, 82-84 Just had the cosmetic lines, that's it.
Old Aug 3, 2006 | 04:40 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
apologies.
I think prudent posting on both our parts is neccessary here.
Old Aug 3, 2006 | 04:59 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
Originally Posted by J's T/A
Are you kidding? your other post is about ten down on this same board and I thought I answered your question pretty well along with others. https://www.thirdgen.org/forums/inte...3-84-bird.html
i appreciate the info but you dont have to be a jackass too
you didnt have to reply in the fashion that you just did
if you were paying attention then you would see that this tread was started before the other one,,
and i was needing to find out ASAP and i mean quick like, as i am trying to buy one from a guy with a later car
but, noooooooooooooooo........................
sigh,
i have my reasons for wat i do, please dont be another jackass second guesser know it all personality type
we are just all here to learn and help and enjoy the cars
thanks
Old Aug 3, 2006 | 09:10 PM
wildjeff's Avatar
Car: 1983 Trans Am
Engine: L69 5.0L HO
Sorry if I wasn’t clear, I tend to ramble or leave out pertinent information.
Yes, it will bolt right in, I’ve done it.
Vintageracer
Sep 24, 2017 12:34 PM
86IROC112
Nov 7, 2015 06:50 AM
loud91rs
Oct 5, 2015 10:05 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
