cool diy red/white gauges
Car: 89 camaro rs
Engine: 305 tbi soon 78 lt1 400hp
I made these with photoshop, they worked for me pretty well so i figured i'd post them up here. also this is a link to them in my photobucket so you can print them.
hopefully someone will want to use them or something just thought i would share iiiluckyboyiii - Photobucket - Video and Image Hosting
hopefully someone will want to use them or something just thought i would share iiiluckyboyiii - Photobucket - Video and Image Hosting Thread Starter
Car: 89 camaro rs
what i needed something different other than all the crap you can buy on ebay..at least its original something different instead of the same old thing as everyone else. it looks pretty good in there ill post some pics to prove it once i get my cam back next week.
Car: 92 Firebird Conv
Transmission: T-56 w/3.42 Posi
not bad, the little figures are a bit much, especially since they are gonna be covered up by the needle.. the flaming chevy logo looks good.. are they gonna be overlays? if so what materials are you using?
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
itll look good if you decide on ONE little figure and maintain that throughout. withh all those different logos it looks cluttered.
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
I think it looks cool. But as purplez said, you should probably stick with one figure. Good idea though. HINT: You should make a set for firebirds.
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Car: 1985 IROC
Axle/Gears: no idea
Im thinking of something like this, but my final result will be totally different im sure. This is just a rough draft of what potential these gauges have. If printed on good paper with a good printer then these will be nice.
Remember, what I made is TOTALLY rough draft. I dont have the time at the moment to put a decent amount of work into these.
Ill end up changing most of the colors but this is what ive done so far with it.
Also, care to explain how you made the originals? I have a 145mph spedo so this wouldnt even work for my car in its current state.
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
um, corvette? and yea they look okay, all those little things look dumb though. just put something simple on the tach and speedo.
Car: 1985 IROC
Axle/Gears: no idea
stick with one color for the face, and one for the numbers and figures. itll look less cluttered. and less rainbow too.
Car: 1985 IROC
Axle/Gears: no idea
Reason I like the "rainbow" is because it will generally let you know by color how fast you are going. When you normally look for something you are missing you generally look for its color first amongst everything else. It will catch your eye easier and make it so you can keep your eyes on the road more. But of course, I never follow logic and I love rainbows.
I will end up toning all the colors down making them more dull and not so "hey, im bright and annoying"
I understand its all constructive critisism but I dont know if you understood why I made the colors the way I did. Hopefully you do now.
no im not trying to just knock down your designs. im more of a minimulist(sp?) myself. i use the "less is more" phrase in design and ideas alot...... except when it comes to power
Car: 1985 IROC
Axle/Gears: no idea
Me too, when it comes to certain things that is. Like my computer, minimalist like crazy. Im more of a function over form kinda person when it comes to some things though. I work too damn much to even attempt to put the kind of time I would want to into these gauges, plus I own a 145mph spedo. If anyone has requests for these, pm me and ill see what I can do.
there is a guy that took a crack at making these awhile back, if you do a search youll find his pictures, they look REALLY good. i bet if you talk to him hell let you use his design. he used a 145 speedo, but he extended it to a 155 speedo. it might just give you some cool ideas too. ill see if i can find it...
heres a link. if you do use his designs youll probably want to PM Abubaca first.
Flames?
Lets see it installed. It looks pretty good so far. Im going to change mine out soon so just want to know if the white ones can be altered and still look clean. I had white gauges with flames in my fourth gen z28 but they dont make them for thirds.
Car: 87 Camaro IROC
post a pic of them installed in the car, only then will we be able to critisize you
j/k...post some pics
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
You must be joking.
