About to order Carpet : ) need last min. advice
Old Aug 29, 2006 | 10:25 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I have been dealing with Car motor sports... and im not sure of this whole backing deal. SHould i get standard backing or rubber. Did original carpet have rubber. I dont want to pay 400 bucks.
heres the priced. Im getting ultra premium definintly
82-92 F-Body(Chevy Camaro, Z28, IROC-Z, SS Camaro; Pontiac Firebird, Trans Am, GTA Trans Am, WS6 Trans Am) INTERIOR & CARGO Compartment Set
$249.95 (Standard Backing)
$319.95 (OEM Rubber Backing on Interior Carpet only)
$389.95 (OEM Rubber Backing on Both Pieces)
$309.95 (Std. Poly Backing/OEM Plus Ultra Premium Carpet)
$379.95 (OEM Rubber Backing-Interior Only/OEM Plus Ultra Premium Carpet)
$439.95 (OEM Rubber Backing on Both Interior and Cargo/OEM Plus Ultra Premium Carpet)
which would you get ? or is there anywhere with the same carpet cheaper?
Old Aug 29, 2006 | 10:37 AM
84'Firebird's Avatar
Car: 84' Trans Am
Engine: 5.0 H.O. L69
Axle/Gears: 3.73 Disc Brakes
Check out hawks, but if you want show quality go for the $400, or something that looks okay go with the $200
Old Aug 29, 2006 | 12:45 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Well I am getting the ultra premium. I cant decide if I should get rubber backing or standard backing.
Old Aug 29, 2006 | 05:47 PM
Pocket's Avatar
Car: 91 Trans Am
Stock had rubber backing which was destructive if water ever got behind it
I got a complete set of ebay from A1Auto - $250ish i cant remember
Most people swear by it, I think it looks good unless you know what your looking for then theres some irregularities and misdyed threads
Fitment was good but could have been better. Its cut oversize so you can trim it down to perfect fit
Only precut hole was for the shifter and it needed to be trimmed larger
Hope that helps
Old Aug 29, 2006 | 10:25 PM
97ramsst's Avatar
Car: 2008 F350 SuperDuty & few F-Bodies
Engine: Twin Turbo 6.4L Power Stroke
Transmission: Yeah, it has one.
Axle/Gears: Yeah, some of those too.
I got the ACC carpet from A1Auto for my 87 Formula as well and I am very pleased with it. Mine fits good and looks great. Unless you are restoring a rare model and want to be "concorse" grade I would save the extra money and go with them....I am very picking and was not dissapointed at all. I would give the kit a strong 9 on looks and fit and a 10 on value.
On a side note as stated above none of the holes were pre-cut and it was a small pain to install but not that bad.
Old Aug 30, 2006 | 12:09 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Jim85IROC sells the same carpet as Car motorsports and he can do a little better on the price of the non rubber backed stuff, IIRC
Old Sep 1, 2006 | 08:37 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
I got the rubber backing when I ordered from CM, and am glad I did. My factory carpet had the rubber backing, and this was a pretty close match to it. Downside is that the carpet is heavier, upside is that it is a bit more insulation and may help reduce noise.
As for the water issue, it should not get wet in the first place. If it does on a regular basis, such as a daily driver, then you would be better off without the backing as it will retain the dampness behind it.
The ultra premium is definately a step up from the more commonly available ACC stuff. I got samples of both (from different suppliers to make sure) before I purchased and the difference is obvious when comparing them side by side. The ultra premium from CM is denser and thicker.
Old Sep 1, 2006 | 10:43 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I got the one from Hawks, it was the same as my stock carpet as far as material. They however did not cut any holes in it. Incidently, I cut too much off near the center console down by the feet, but I patched it.
webeeZ28
Sep 14, 2015 12:00 PM
MORREALE5
Sep 13, 2015 09:01 PM
89 formula TPI
Sep 7, 2015 10:19 AM
mrdevontay
Sep 2, 2015 08:04 PM
