grant steering wheel & airbag...
Old Oct 15, 2006 | 07:40 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
has anyone ever installed a grant steering wheel in a camaro with an airbag & deleted the airbag? if so,what did you use to install it?
Old Oct 15, 2006 | 08:16 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
hey girl i was looking into a rant will not be hard just pull out the light bulb in the cluster so it will not stay on and intall the grant with its adapter thats about it wich grant you looking at installing? i think im going with the challanger series 414 since my interior is all black
Old Oct 15, 2006 | 09:10 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Only pic I have right now but yeah they will work, if i remember correctly i had to place a shim between the column and wheel adapter to keep it from rubbing. Sorry dont have the part #'s...........jt
Old Oct 16, 2006 | 04:11 PM
RCAR7395's Avatar
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
I did this Grant, but never got the horn working yet. I think I need some other kit or parts. I also may need a new plastic piece in the column. I think it's called a canceling cam. If ya do replace the wheel, make sure you get the right installation kit for that wheel and that it is right for the car. I think they make these wheels and kits a little tricky for an ex-airbag car. In other words, they seem to be a little off when it comes to lining up the mounting holes and horn button hole. I don't think they want the airbag deleted. And I had to shim mine with a few extra washers as spacers so it wouldn't rub.
Attached Thumbnails grant steering wheel & airbag...-dscn0424.jpg   grant steering wheel & airbag...-dscn0425.jpg
Old Oct 16, 2006 | 04:51 PM
Engine: 283
thats the problem im running into guys,when i turn the wheel it makes a clicking or rubbing noise & theres this big ugly gap between the column & the plastic piece. so shimming it should quit the rubbing or clicking noise?
Old Oct 16, 2006 | 06:30 PM
RCAR7395's Avatar
Engine: 6.0 Vortech
Transmission: 4x4
Depending on where you shim it, yes . It should work and stop the rubbing noise. Did the wheel feel like it turned different? A little resistance when it rubbed? Or it didn't return back as fast when you let go after a corner.
Sounds like it needs some kind of spacer.
Old Oct 16, 2006 | 07:39 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I used one of their billet hub kits and didn't need to shim it at all. I'm using a three spoke Collectors edition wheel.
Old Oct 16, 2006 | 08:03 PM
dubcity's Avatar
Car: 85 Camaro iroc
Engine: 305ci HO
Where did you get your shifter **** from?
Old Oct 17, 2006 | 02:30 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I bought it here. Mustang Composite Race **** Its made for the mustangs so the thread pattern is differnt. I had to retap my Pro 5.0 shifter to make it work.
Old Oct 19, 2006 | 08:00 AM
Engine: 283
thanks guys ill see what i can come up with.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
