drag cars/weight natzis post your interiors
Old Oct 24, 2006 | 09:27 AM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
So I want to know how far people take the interior of their car down for the time they run. Please post timeslips, pics, and race weight if you know it, Please no guestimates..
Thanks,
Matt
Old Oct 25, 2006 | 09:21 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
I don't have any pics of my interior, but all I've done for weight reduction is remove the back seats. Stock gauge cluster was removed for a set of AutoMeters and I made a new console plate to fit the B&M shifter into. All the A/C ducting is removed but that weighs less than 10 lbs. at most. The rest of the interior is stock. My car weighs 3350 with me in it and 1/2 tank of gas and runs 11.60's.
Old Oct 25, 2006 | 09:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its spelled ****
Old Oct 26, 2006 | 03:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you're good, it'll look like stock, but lack the carpet padding, excessive structure, ect.. behind it.
if you're not going for that look, then it looks..... like everythings gone.
theres not alot to really talk about/show.
Old Oct 26, 2006 | 07:47 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
well I actually want to find out how the interiors of drag only cars look.
Old Oct 26, 2006 | 08:31 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
wayfast84, what color is your firebird? looks like something i would have.. haha.. heres some of my interior.. since these, i have a very small console, wires have been cleaned up, and i have 2 racing seats with g-force 5pt. harnesses..
Attached Thumbnails drag cars/weight natzis post your interiors-dsc00425-1.jpg   drag cars/weight natzis post your interiors-dsc00471.jpg   drag cars/weight natzis post your interiors-dsc00472.jpg
Old Oct 26, 2006 | 08:34 PM
5678TA's Avatar
Car: 1984 Trans Am
forgot to add, this is not strictly a racecar.. its a very rugged streetcar.. haha.. no radio, no A/C, no fan for that matter, but it does have power windows..
Old Oct 29, 2006 | 10:02 PM
TorqueWolf's Avatar
Car: 85 TA TTA clone
Engine: 355sbc (turbo planned)
Axle/Gears: 9 bolt rear disk
dosent step plate weigh a ton? would seem to me like it weighs more than the plastic stuff did
Old Oct 29, 2006 | 10:07 PM
Camaro-please?'s Avatar
Car: 88 Camaro Sport Coupe
Engine: 305 TBI
So not worth it
Old Oct 29, 2006 | 10:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'm sure that's thin stamped aluminum that looks like diamond plate. It's certainly not 1/4" steel or something. Might weigh 5 pounds total for all that sheet aluminum, the local hardware store sells them in large sheets the same way.
Old Oct 29, 2006 | 10:38 PM
5678TA's Avatar
Car: 1984 Trans Am
its aluminum.. its only laid over the stock dash.. only weighs like 2 pounds for all of it.. i'm gonna trash the whole dash.. stock section and all for a new custom dash.. solid aluminum sheet straight across.. clean and simple.. but thats later..
Old Oct 29, 2006 | 11:41 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Yes, the aluminum checkerplate isnt very heavy. But if you were looking to take off every single pound you possibly could, i would look for an alternative to that.
Old Nov 5, 2006 | 11:47 PM
Brettlinetta's Avatar
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
Looks like power seats too
Nice
Old Nov 6, 2006 | 12:29 AM
5678TA's Avatar
Car: 1984 Trans Am
Nice
with the roll cage, i had to relocate the upper mount for the factory belts.. on top of not having the little loops for the belts to go through that connect to the seat itself, the belts would rest right across my neck.. i ditched those for g-force 5 pt. harnesses and needed racing seats to use them.. so the power seats were trashed for some cheap racing seats..
Old Nov 6, 2006 | 12:47 AM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
I have removed the headliner, all interior trim, pulled the dash to remove the remains of the ac and any thing that didn't work or not nessary to run, i have not removed the back seat yet. Under hood, the ac box was removed by the previous owner. I have also changed to center line wheels to reduce rotating mass. when i got the car it weighed 3375 3/4 tank now 3195 with 1/4 ran a 12.93 @ 103
Street Lethal
Apr 30, 2019 12:14 PM
lee01
Apr 9, 2016 01:56 PM
z28_AJ
Aug 27, 2015 08:59 PM
neekolzun
Aug 24, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
