Shift knop question
Old Nov 12, 2006 | 01:09 PM
newRSdriver's Avatar
Car: 90 RS
Engine: 305 TBI
Transmission: 5-speed
Shift knop question
I don't really like the black ball shift **** and was thinking of getting the hurst T-handle. But how do i take of the black ball?
Old Nov 12, 2006 | 01:18 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Standard ***** unscrew, auto ***** have a little clip on the front og the ****. Use a knife or something and pry the clip out, the **** will come out.
Old Nov 12, 2006 | 05:52 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
If you have the black Camaro "8 ball" looking Automatic ****, You'll need to pull the pushbutton straight out of the shaft, and then you'll need to remove the C ring clip to get the **** itself off.
Old Nov 12, 2006 | 06:53 PM
Car: 90 RS
Engine: 305 TBI
I have a manual transmission and i tried all day but i couldn't get it to unscrew. could it be stuck?
Old Nov 12, 2006 | 07:11 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
The manual **** just unscrews, nothing else to it. But it's 'loctited' on from the factory, so yes, it prolly feels like it's stuck. Get a good, strong, firm grip, maybe even using something to wrap around it(like part of a non-skid carpet pad) and twist! It should break loose just before you passout, lol!
Old Nov 12, 2006 | 09:17 PM
North's Avatar
Car: 1986 Camaro Z28
Engine: 400 chevy small block
Transmission: 5spd
ya mine is a maunual with same **** and it screws right off
Old Nov 13, 2006 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might also consider B&M's Hammer shifter (I've tried several different products and this is my personal favorite). It's a direct fit (i.e. it uses no inserts).
JamesC
Old Nov 14, 2006 | 08:07 PM
Car: 90 RS
Engine: 305 TBI
Thanks guy. I'll let you know how it goes.
crazynights
Aug 21, 2015 06:53 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
dhonda200
Aug 11, 2015 11:50 PM
