monster tach mounting location
Old Jan 23, 2007 | 05:26 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
was planning on installing a 5" tach and was looking around for a good spot. I don't think there is much room on the steering column, plus I use my tilt each time I get in/out and it would hit the top of the dash anyway. Anyone with a good mounting location along with any other aftermarket gauge locations ie: a radio delete panel or brackets hanging from the two top center vents. Pictures would be good if any...
Old Jan 23, 2007 | 05:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i put it under the center vents on the dash. Some of my buddies run it on the dash all the way to the left near the pillar, different strokes for different folks basically.
Old Jan 23, 2007 | 05:54 PM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
I like it under the center vents also . Looks good and no holes in the dash pad .
Old Jan 24, 2007 | 07:40 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Me also
Old Jan 24, 2007 | 01:42 PM
Car: '86 Z28
Engine: 355
so what kind of bracket would you use since it would have to be mounted with the bracket on top of the tach, one that is supplied with the tach or something fabbed...
Old Jan 24, 2007 | 02:24 PM
A Honduh would be a good spot...
Old Jan 24, 2007 | 07:26 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
lol.
I mounted mine on top of the dash all the way to the left under the pillar. It looks pretty good there, b/c I have teh pillar gauges and my tags on the windsheild sort of block it.....sort of.
Old Mar 26, 2007 | 06:19 PM
Car: '86 Z28
Engine: 355
Re: monster tach mounting location
ok so I finally got it all done. What took so long was fabbing up the gauge panel where the radio used to be. It was harder to make than I thought it would since I wanted everything perfectly aligned. I'm happy with it and beats staring at the empty hole anymore...
Old Mar 26, 2007 | 06:47 PM
Car: 92rs
Transmission: 350
nice job , looks good
Old Apr 7, 2007 | 07:47 PM
badpontiac's Avatar
Car: 1986 pontiac firebird
Engine: 2.8l v-6
Transmission: 5-speed
Axle/Gears: stock
my tach is mounted in a goffy spot that my friends hate right beside the center console by my gas pedal leg i like it
Old Apr 8, 2007 | 01:17 AM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
mine is mounted rite infront of the old tach.. looks good there imo.. shift lite is somewhat hidden...
Old Apr 8, 2007 | 06:42 AM
Car: '86 Z28
Engine: 355
thats originally where I'd like to have put it, but I'm always using my tilt and for me it would have been hitting the dashpad and there was plainly just no room. I also thought about the A-pillar but since I have a cowl I would have been eliminating even more visibility from my view...
Old Apr 8, 2007 | 11:29 AM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
i have no problem with my tilt stearing.. only thing that its in the way of is turning the key but u get used to it i can get a pic if ud like i to have a cowl hood thats why i put mine there
Old Apr 9, 2007 | 08:13 AM
Car: '86 Z28
Engine: 355
yeah I'd like to see a pic 'cause if I move mine to the same location it could free up some more room for more gauges...
Old Apr 14, 2007 | 10:20 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
if you want a better one let me know..
Old Apr 15, 2007 | 08:43 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Here is how I did mine. Shift light in the cigarette lighter hole, tach in the hole where the stock one was.
Old Apr 15, 2007 | 01:33 PM
Car: '86 Z28
Engine: 355
that looks like a clean way to do it, nice job. I ran all my wires through the cigarette lighter hole though and I dont feel like rewiring it, but that's a way I would never have thought to do...
Old Apr 15, 2007 | 01:59 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Mine is under the center vents, however I mounted it to the side of the dash (next to the cigarette lighter). I also flipped my shift light to the other side. Then I just tucked in the wires behind the radio trim bezel. All I need is a short piece of black split loom to hide the short length of wiring between the tach and bezel, I'm just too lazy to get around to it.
Old Feb 16, 2012 | 10:08 AM
3genpio's Avatar
Car: Trans Am
Engine: 383 Accel ProRam single plain EFI
Transmission: t-56 Spec #3
Axle/Gears: 4 gen 3.73:1
do anybody have pictures of 5" monster instaled in firebird? i`ve seen many in camaros but how does it looks in bird?
thanks
Old Nov 28, 2018 | 06:47 PM
atikovi's Avatar
How did you mount that in the stock hole? Aren't those tachs 4 or 5 inches deep?
Jeremys87
Jul 14, 2022 09:08 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
