new gauges
Old Jan 29, 2007 | 01:06 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
new gauges
so i just got a 140mph cluster for my bird. mines a 89 and it came out of an 89. it should just drop in right? has anyone tried changing the little rubber things on the lights to get a different color gauge face? thanks and tips on rolling back an odometer? the new ones got 205000, not quite the 60,000 on my car.
Old Jan 29, 2007 | 01:16 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I've tried them, and I suggest going with these "WLED 5-LED Wide Angle LED bulb" instead. They’re much brighter and I very happy with them. The rubber sleeves were not bright enough to read the numbers on the speedometer or on the other gauges. Below is the link.
http://www.superbrightleds.com/cgi-b...gi?product=CAR
Do a search for "WLED 5-LED"
Old Jan 29, 2007 | 06:12 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
yep. Same bulbs I got and I love them. Shiping was fast from the as well.
Old Jan 29, 2007 | 09:11 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
do you guys have any pics of your dash with the new LEDs in?
Old Jan 29, 2007 | 10:18 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I tried but my camera doesn't do it justice.
Old Jan 30, 2007 | 07:31 AM
Car: 89 RS
Engine: 2.8
im with ringo. My pics make it look like only parts are lit up, and that tthe numbers really arent visible, yet in reality the whole guage is lit and the numbers and dashes are plainly visible.
Old Jan 30, 2007 | 09:11 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
damn cameras, so any tips on rolling back the odometer?
Old Jan 31, 2007 | 01:26 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Why do you want to roll back the Odometer?
Old Jan 31, 2007 | 08:01 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
id rather have actual mileage on my odometer not 205000. i took the cluster apart today for cleaning and pulled the speedo up just to check the guts out. to roll it back is it possible to just turn the gears with a flathead? any input is appreciated.
Old Jan 31, 2007 | 09:25 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Sorry I'm not familiar with the Firebird dash I have a Camaro. But when I replaced my 110mph speedometer with a 145mph one, I removed the odometer from the 110mph and installed it 145mph one.
Old Jan 31, 2007 | 09:30 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
did you just have to take the 2 screws off the gauge face then put the old odometer on ?
Old Jan 31, 2007 | 09:53 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
This is what I did, although there are others who have done it without removing the faceplate. I made special notice as to the location of the position of the needle. I then carefully pried it off. I removed the 2 screws holding the faceplate to mechanism. I removed the small clip on the axel of the Odometer. I remove odometer and replaced it with the original and put everything back together in reverse order.
The speedometer and odometer work perfectly.
Old Jan 31, 2007 | 09:58 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
ok ill try that when i pull out the 120 gauge. thanks for the help ringo
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
