Signal control lever help...
Old Feb 25, 2007 | 12:44 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Transmission: Turbo 350
Axle/Gears: Stock 2.93
Hey guys...
When I bought my '82 TA it's signal control lever it was busted off with just the metal lower arm part remaining with a few wires sticking out the end of it. Here's pic of it currently below. I've since bought a NOS lever; is this a tough repair to make? Is it going to invlove taking apart any of the steering column to replace it? Thanks.
Old Feb 25, 2007 | 12:48 AM
83Chevy__Camaro's Avatar
the lever should just pull out, with a little muscle, and you should be able to line up and pop the new one in, the end piece has grooves so it only goes in one way.
Old Feb 25, 2007 | 12:53 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
So just grab the arm that's left there & pull it straight out towards the driver's door? New one just pushes right into place? What about the wiring?
Old Feb 25, 2007 | 01:07 AM
thats correct, i took mine out 2 weeks ago tightening the 4 steering wheel tilt bolts, the lever arm pulls out, its all self contained.
Old Feb 25, 2007 | 01:21 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Thanks man!
Old Feb 25, 2007 | 12:28 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
So what happens to the wires for the cruise control?
Old Feb 25, 2007 | 01:09 PM
cant help you there dont have cruise control
Old Feb 25, 2007 | 01:42 PM
Pocket's Avatar
Car: 91 Trans Am
cruise control wires are fished thru the column, they are a major PITA
If you dont much care for bein perfect you can run them on the outside of the column
Only about 3" of wire will be exposed before they dissapear under the dash
Old Feb 25, 2007 | 08:35 PM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
OK...but the lever arm iteself still just pulls straight out & the new one pops straight in? Do the end of the wires for the cruise actually plug into something inside the steering column or under the dash?
Old Feb 25, 2007 | 10:37 PM
Pocket's Avatar
Car: 91 Trans Am
The stalk pulls out yes, you have enuff slack wire to do this
Wire is ran thru the column, its difficult to wiggle it out because the plug snags everything, Ive never been successful at fishing the new plug back thru it
THe plug-in is under the dash, if I remember right its a very thin black coated wire in a very strange exposed wire end, the harness plug I think is clear/white
Been a while since I looked
Old Feb 27, 2007 | 12:00 AM
85camarocrazee's Avatar
Car: 86 IROC
Engine: MAS Crate 350
Transmission: 97 T-56
Axle/Gears: 97 rear 3.43's posi
Tie a string to the other end of the wire harness. Pull them out with the string attatched, re tie your string to the new wiring and pull it all back through. Plug in the new handle. Done deal.
Old Feb 27, 2007 | 08:54 AM
Ian'sTA's Avatar
Car: 1982 Trans Am
Engine: Chevy 350
Thanks for all the great replies...will do!
wigmobile
Feb 26, 2025 02:56 PM
Veaceonee
Sep 29, 2016 08:15 PM
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
TrevinE
Sep 14, 2015 03:20 PM
