radio delete idea...
Old Mar 26, 2007 | 05:55 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
So I was sick of looking at the hole where the radio used to be so I fabbed a little something up...
it actually wasn't as easy as I thought it would have been since I am a perfectionist and like everything nice and aligned so getting the two holes the right side and spaced evenly apart took some time. Look better none the less. Also mounted the tach while I was at it...
Old Mar 27, 2007 | 12:40 PM
Car: '86 Z28
Engine: 355
Re: radio delete idea...
ok so I didnt know it took so long for a thread to actuall make it to the forum after you post it. Sorry for the double post, can someone lock or delete both of these actually 'cause I posted this again in the "monster tack mounting location" thread. Newb error, my bad...
Old Mar 30, 2007 | 05:33 PM
Ucantcme57's Avatar
I don't get why you have 2 tachs?!?!?!?!?
Old Mar 30, 2007 | 10:35 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Factory tach isn't the most accurate thing on the planet, but on the street its inaccuracy doesn't effect much of anything. My guess is that its for appearance more, or the ease of knowing your RPM and not having to look down?
Old Mar 31, 2007 | 11:46 AM
Car: '86 Z28
Engine: 355
well the plan was to have as many tachs as I could on my dash... why the hell would someone get a tach, unless maybe their factory one doesn't work?? Guess some people are too quick to ask stupid questions then to assume why someone has done something to improve their car, and why not ask the other couple hundred thousand poeple who own monster tachs why they have 2 tachs...
Old Apr 3, 2007 | 04:20 PM
Ucantcme57's Avatar
I apologize, You said you were a perfectionist.. Didn't know if you were going to be fabbing up a whole new guage cluster...
Old Apr 3, 2007 | 04:56 PM
Gottork1967's Avatar
Car: 83 Firebird
Transmission: 2004r
Axle/Gears: 10 bolt posi 3.08
WOW camaro, someone asks a simple question and you blast them back with an answer like that.. kinda harsh I think.
If your factory tach did not work, why not try and buy a used tach or mount your monster tach inside the dash, since you were such a perfectionist. To me ( I am a perfectionist too) I would not want two tachs hanging in one spot.
Old Apr 3, 2007 | 05:30 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Adding more gauges to replace inaccurate ones:
Old Apr 7, 2007 | 01:00 PM
DIGGLER's Avatar
i would have had to blast him too, thats a fairly retarded question. there is thousands of cars out there with 2 tach's since the factory one is just about useless at the track. and there is no sense in removing your stock tach just because you got another more accurate one on the dash. plus, the aftermarket one has a shift light.
personally, i am running a factory 4th gen cluster with an autometer shift light mounted on the column.
Old Apr 7, 2007 | 01:10 PM
Car: 83 Firebird
Transmission: 2004r
Why do you have to BLAST someone cause they ask a question, this board is here for help, not to make people feel that they are stupid, and by your BLASTING people, you only giving off the bad vibes, and then I can see either a flame war or a new member stop asking for help cause of one person.
If you cannot answer without slamming someone, then why answer?
Especially since you have no clue exactly what they are trying to convey since its typed and not said with expression. Just my thoughts..
Old Apr 7, 2007 | 03:22 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
i personally dont like the huge rpm gauges, and i couldn't drive w/o a radio..if it was a track only car it would be one thing. but the 2 gauges in the radio spot is clean. jus my .02
Old Apr 7, 2007 | 09:57 PM
Car: '86 Z28
Engine: 355
I agree I could have and should have been a little more subtle in my reaction and I apologize. The last thing I wanted to do was start another flame war or lose any respect from anyone on this forum, especially since I'm the new guy. But my reasoning for the new tach and gauges are the same as anyone else's reasoning, they are plainly more accurate and make better replacements for damaged pieces. As far as being a perfectionist and not replacing them in the gauge console, I didn't want to shell out $120 for a new (aftermarket) bezel, and the speedo, volt and fuel gauge still work! (for now). As far as the second tach still being there, maybe I'll fab up something to install a different gauge in it's place like a clock or something, heck I am always running late...
Old Apr 7, 2007 | 11:42 PM
Car: 83 Firebird
Transmission: 2004r
Well good luck in your efforts, sounds like its a on going project that will always be making steps forward..
Keep us posted on how its coming along and all, always like pics..
Old Apr 11, 2007 | 11:46 PM
sprtbikeprinces's Avatar
Car: 1990 RS
Engine: 305 tbi
I think it looks sick! Looks clean and very custom, Send it into one of the mags...I like it. I had a tach with shift light on my fourth gen (314hp) and it is awesome to see. I had the same hole I had to look at for a few months and all I could do was use it to hold my sunglasses. Great job!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
