Putting 4th gen seats in a 3rd gen
Old May 8, 2007 | 11:12 PM
iflubyu's Avatar
Car: 1989 GTA
Engine: 5.7l TPI
I know they will bolt right in, but is there anyway to convert the power hook ups?
My GTA has power seats on both, and so do the 4th gen replacements, but the hook ups are different.
Anyone done this before? Can the seats be swapped from rail to rail?
any info or suggestions appreciated, thanks!
Old May 8, 2007 | 11:30 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Putting 4th gen seats in a 3rd gen
direct bolt in the plug for power seats may just be different but thats an easy fix
Old May 8, 2007 | 11:37 PM
LIL BASTARD's Avatar
Car: 1985 Berli
Axle/Gears: stock Berli
Try putting the power wire to the power wire, the ground to the ground, and try the other wires to see where hey need to go.
Old May 9, 2007 | 01:28 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You should be able to tap a the main power wire to run the others. In the attachment that I provided, I copied what another member here did for his seats. I did this same search about a month ago and it took me like 4 hours to sift through all the crap posts that didn't mean anything before I found what I was looking for. I don't know how well it will cross over to what you have, but it should help some. Best of luck to you. I"ll be getting my seats here some time this week so I'll be doing this same thing very soon.
Old May 9, 2007 | 09:33 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Since we're on the topic...
Will non power T/A seats readily bolt in to a third gen t/a?
EX- do you just remove the old seat and track, and the 4t gen track and seats bolt in on the same holes?
Old May 9, 2007 | 12:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Yes. Remove the entire third gen seat assembly. Put the fourth gen seats in, install bolts. That simple! Well, mostly that simple. Nothings ever THAT simple.
Old May 9, 2007 | 05:31 PM
iflubyu's Avatar
Car: 1989 GTA
Engine: 5.7l TPI
do tell...
Old May 10, 2007 | 08:22 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Originally Posted by iflubyu
do tell...
Your old seats have a power wire and a ground wire. Your new seats have a power wire and a ground wire. Figuring out how to hook them up shouldn't require a whole lot of concentration. Cut the connectors off and crimp and/or solder them together!
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
