new wiper/cruise/turnsignal lever?
Old May 10, 2007 | 04:32 PM
Kandied91z's Avatar
need a new one as it doesn't click when i pull it back for the high beams it just flops back.
would this work
http://cgi.ebay.com/ebaymotors/84-89...QQcmdZViewItem
is there a better alternative?
also, i have never fixed one of these. are they difficult to change out?
Old May 10, 2007 | 04:46 PM
Gr89RS's Avatar
Car: '02 Z06
Re: new wiper/cruise/turnsignal lever?
The only problem I'd see with that one is it has white lettering while the later cars have yellow lettering. Sorry no experience changing them here either.
Old May 10, 2007 | 04:50 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Wow never seen an aftermarket lever like that. I wonder how the quality is. Figuring how almost all GM lever's text wear off in a few years...kinda annoying and its hard to find good one at the JY and new they are over $60-70.
To change them out all you do is pull and turn to the left, it kinda clicks in and out. Make sure you pull from the base(closest to the steering column so it doesnt break apart). Then there is a 4 wire connector. Simple.
Old May 10, 2007 | 05:35 PM
Kandied91z's Avatar
good deal, appreciate the input. does my problem sound like it's the lever itself or something in the column?
as to the piece on ebay it's only $9 plus shipping. if it's remotely close it will work. i'm not too concerned with color on this piece but i agree it's nice to match. the $60 savings can go towards other things though on this car. thanks!
Old May 10, 2007 | 05:41 PM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Hmmm, I could use 1 of those myself. Not bad for the price.
Old May 10, 2007 | 07:34 PM
Pocket's Avatar
Car: 91 Trans Am
Thats a common replacement youd find in the HELP section of autozone
Just a FYI your high/low beam switch is in the column not the stalk you listed
Old May 11, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Could the problem be the high beam switch and not the signal stalk itself?
JamesC
Old May 11, 2007 | 07:17 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Really need to pull the column apart to figure it out, especially if the tilt mechanism is loose. The lever simply engages a rod/cam for the high beam switch farther into the column. So it's more likely improper engagement or a bad high beam switch.
A loose column can cause improper engagement and the symptoms you describe.
Old May 11, 2007 | 07:24 AM
LowRyder's Avatar
Car: 92 RS Vert
Engine: 355
Axle/Gears: 342
sounds to me like the highbeam rod has fallen off either the lever or the switch. If its still in the switch which is about 3/4 of the way down the column, then its probably off the lever. Pull the sterring wheel and dig into the column. Its an easy fix. Easier if you have snap ring pliers to release the C clip that holds it together under the steering wheel. Shouldnt take more then about 30-45 mins to check/fix if you've never taken a column apart.
Old May 11, 2007 | 08:02 AM
naf's Avatar
naf
Oh and you can 'borrow' the wheel puller and lock plate remover from AZ or one of the others.
Old May 12, 2007 | 01:35 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Just about every Third Gen restoration magazine sells those. Classic Industries, Year One, the Paddock etc. Ebay works too though.
Old May 13, 2007 | 02:34 PM
Kandied91z's Avatar
appreciate the input everyone!
Old May 14, 2007 | 02:43 PM
jasonsknight2k's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8 V6
Yes thanks guys I'm having the same problems!
Jason
Old Jul 13, 2007 | 03:18 PM
mathlic's Avatar
would this work
im not even gonna lie dude, i just had the same problem and just bought the EXACT same lever and received it today...quality is pretty solid tooo..not flimsy or delicate..feels pretty nice too :-)
...i still have yet yo install it, but im just gonna jump into it...how hard can it be?
~MatT~
Old Jul 14, 2007 | 11:04 AM
loud91rs's Avatar
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
I have this problem, as well as the left turn signal not canceling out ever but the right one does. Think it's the stalk?
wigmobile
Feb 26, 2025 02:56 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
Todd84Z
Sep 4, 2015 08:02 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
